CMDRLawliet Posted March 11, 2017 Posted March 11, 2017 So after using Don's ROM Renamer to audit most of my games, there were about 70 missing. I didn't really want those 70 in the romset anyway so I deleted the .7z files from the ROM location and replaced them with the .nes files from my temporary folder. After that, I went back to RLauncher UI and for some reason, after even rebooting and performing multiple system audits, it still sees those games in that folder and says they're still missing. What's going on? How can I get these games to be recognised? What exactly is RLauncher UI seeing and how can I fix it? Please, I really need help, so some would be greatly appreciated. Cheers!!~
Guest Posted March 11, 2017 Posted March 11, 2017 Two things...- RLUI matches by name.- File extension must be in list of extensions for that emulator.Check those. Sent from my iPhone using Tapatalk
CMDRLawliet Posted March 12, 2017 Author Posted March 12, 2017 10 hours ago, agent47 said: I'm not exactly clear on what your asking but I'll give it a shot. If you're saying that you don't want those games listed in the audit at all you would have to remove them from your HyperSpin database file for that system because that's what RLUI uses to generate the list. If you just don't want them showing up in your HyperSpin wheel and don't mind them showing up in the RLUI audit you can set the roms only filter in HyperHQ (and also set the rom path and extensions) and HS will only show the games you have roms for. AH! That made much more sense. I fized the problem, so thanks for that! Also, quick question. Can you get onto EmuMovies right now? I keep getting an Error 504 so I can't get the video snaps I need for my NES menu
