kagaden Posted March 27, 2017 Posted March 27, 2017 I can reproduce this 4/5 on my setup with the latest official Hyperspin 1.4 Summary: There is a race condition where if you select a system/game before it loads a full screen theme movie, the sound will continue to play for the movie until Hyperspin is reset 1. Launch Hyperspin 2. View a system or game theme that uses a full screen theme movie 3. Very quickly (before it loads) either press Start (4/5 repro) or move to another game/system theme (1/5 repro) 4. --> The sound for the movie will play continuously until you reset Hyperspin. It will play over emulators, other themes, etc. Edit: I should note that this report is not for windowed gameplay movies. It is for full screen theme movies. Thanks for the awesome development and support. -K
kagaden Posted August 23, 2017 Author Posted August 23, 2017 Bump When I overhaul I'm going to stay away from full screen theme movies to work around this.
griffin518 Posted August 23, 2017 Posted August 23, 2017 Unfortunately this is a known issue, but there's a solution that helps to reduce the likelihood of this happening. It's to add a delay within the theme zip which loads the full movie. I'll post a theme zip tonight if I have time. Download my RocketLauncher bezels: http://hyperspin-fe.com/files/file/14367-griffin518s-bezel-depot/ Best of MAME HyperSpin XML: http://www.hyperspin-fe.com/files/file/11710-griffin518s-best-of-mame-xml-database/ Best of MAME bezel pack: http://www.hyperspin-fe.com/files/file/11711-griffin518s-best-of-mame-bezel-pack/ Custom MAME ini files w/HLSL settings: http://www.hyperspin-fe.com/files/file/11712-griffin518s-best-of-mame-mameuifx-ini-files/
NIGHTKILLER05 Posted August 23, 2017 Posted August 23, 2017 4 hours ago, griffin518 said: Unfortunately this is a known issue, but there's a solution that helps to reduce the likelihood of this happening. It's to add a delay within the theme zip which loads the full movie. I'll post a theme zip tonight if I have time. I add myself to the request, thank you !!
griffin518 Posted September 1, 2017 Posted September 1, 2017 Hey guys... completely forgot about this. My bad. Rename this theme zip to match your ROM name and put it in your theme folder. This only works for the use case where you have a full screen "cinematic" style video as your theme. The video must be split from the theme. dkong.zip Download my RocketLauncher bezels: http://hyperspin-fe.com/files/file/14367-griffin518s-bezel-depot/ Best of MAME HyperSpin XML: http://www.hyperspin-fe.com/files/file/11710-griffin518s-best-of-mame-xml-database/ Best of MAME bezel pack: http://www.hyperspin-fe.com/files/file/11711-griffin518s-best-of-mame-bezel-pack/ Custom MAME ini files w/HLSL settings: http://www.hyperspin-fe.com/files/file/11712-griffin518s-best-of-mame-mameuifx-ini-files/
kagaden Posted June 11, 2018 Author Posted June 11, 2018 You're awesome, thank you for the work around griffin518!
