Cannot find Matell Intelevision.xml
Centurion1a
Hello,
   I have installed Intelivision emulator and roms, but I can't get it to work when I run HyperSpin. I keep getting the following message: "Cannot find Matell Intelevision.xml."
Hey, I can't see the images there. Just a quick first guess at it make sure you have the "System Name" matching properly. If you misspelled the system name
incorrect, it may not be matching the name of the xml. The correct system name is "Mattel Intellivision" and should match the name of the xml.
If you have the system misspelled "Matell" for example; the xml must match in the corresponding folder or it will kick an error or seem like's its missing.
Hope that helps a bit. if not try to post another screen shot, or log. hopefully someone will see it, and help you out.
