RocketLauncher displays a window then loads the game in HyperSpin
mamefan
It's loading the RL bezel, but it briefly shows a large window that disappears every time I load a game that uses a RL bezel. Is there a way to make the window not be visible at all? This is happening while still in HyperSpin, just before MAME loads.
Have you tried toggling the various hide dekstop/frontend/etc options in RLUI?
Yeah, I'm trying all sorts of combinations of those in the global settings.
In your HyperHQ settings do you have a program set to launch on entering or exiting HyperSpin?
Depending on the system/emulator, this could be normal. Are you using fade? I don't use bezels personally so I've  not encountered the issue.
Yes, EDS via Ledblinky.
Yes, I think fade is enabled, but I don't understand what it does.
Fade allows RocketLauncher to run loading and exit screens before and after games that look nice and clean up the transition from FE to game, making it smoother. Try enabling Fade In and Fade Out in the Global -> Fade - General menu. Different systems sometimes load temp windows just by their nature and fade smooths everything out.
Ok, I'll try. This only happens with RL bezels. When I'm using MAME bezels in the artwork folder, there are no pop-up windows.
There might be some additional information on the RL forums themselves. I don't use bezels at present and I'm not at my rig to test but I remember having a lil trouble setting them up when I tried them last year. I think the fix to your issue is as simple as toggling the right setting though and hopefully fade helps.
That worked! Thank you! Now, there's a loading screen and no pop-up windows. I also got HLSL working, and everything looks much better on my 48" LCD. It was so pixelated before.
Awesome. The pause screen and HyperPause can be customized as you'd like and it's a great way of browsing system/game specific media and wiki-style descriptions/synopses so it's definitely worth running like that. Glad I could help.
