Database gets deleted when adding a system...
metroplex2k7
Ok, so I had to re-add the Panasonic 3DO to the systems list in RocketLauncherUI.  Well, when I do, and this goes for other systems too, when it gets to the part where it asks for
"No Database"
"Generate Database from Rom List"
"Import Database File"
I choose the Import Database.xml from the database folder and hit ok.  After a few seconds, it says Database could not be found, and then the .xml file that was in the database folder is no longer there.  Any ideas?
Where do you have your .xml?
If you have it in hyperspin/databases/Panasonic 3D0/Panasonic 3D0.xml rocketlauncher should find it automatically assuming you have rocketlauncher and hyperspin configured correctly
That's where I have it.  But it keeps saying file could not be found and the deletes the .xml that was in the folder...
I have it in C:\HyperSpin\databases\Sony Playstation 2\Sony Playstation 2.xml
Where are you adding the system initially, rocketlauncherui or hyperhq? I always add the system in hyperhq first, then refresh rocketlauncheui and I've never been asked those questions before. It's just automatically detected once the refresh occurs
