Mame roms and running in hypersspin
jfprice30
JUst wanted to ask a question without sounding too complicated. This is the example i will give if I try running 1943 in Hyperspin i get errors like bme01.12d and forces me out of that game, and then I will run another game 1942 and it runs perfectly. And now to really complicate things if I run this ROM through Mame emulator its fine runs as it should. Also, I use mame 1.53
Any help would be appreciated
thanks
I think we're going to need some more info. Would you post some screenshots?
bme01.12d NOT FOUND (tried in 1943 1943) bme02.13d NOT FOUND (tried in 1943 1943) bme03.14d NOT FOUND (tried in 1943 1943) bm.7k NOT FOUND (NO GOOD DUMP KNOWN) (tried in 1943 1943) FATALERROR: Required files are missing, the game cannot be run
You're missing some required ROMs, which sound like BIOS ROMs.
When you have a split set, you're going to need BIOS ROMs and/or parent ROMs (if trying to run a clone). Read this: http://docs.mamedev.org/usingmame/aboutromsets.html
Edit: @jfprice30Here's another good one... http://choccyhobnob.com/articles/demystifying-mame-roms/
Thanks griffin I did read those articles and in the end, I got my problem fixed the easiest way for me was getting a newer version of the rom set that I was using i went from 0.153 to 0.18 and everything I try and run they all work perfectly. So problem solved.
thanks
