Why does retroarch default to dualshock controller?
jamesmatthewavila
Everytime I launch a PSX rom (using mednafen_psx_libretro) , it defaults to dualshock controller and I must then go in there, and set it to none.  If I keep it on dualshock, my XBox360 controller (mapped thru xpadder) wont work.  As soon as I set input device to none, the x360 controller works.
I think rocketlauncher is set to start in dualshock mode, you will need to go into the module settings and change it, or switch each game individually that requires the alternate mode. There is a thread on the rocketlauncher forums for epsxe that someone created so it automatically sets the controller. It has every game listed that requires the controller in a different mode to use as a guideline
I'm not home right now, but did you try the per game settings? I think you have to click the + sign and select a game, see if the controller module setting is in there
