metroplex2k7 Posted May 3, 2017 Posted May 3, 2017 Ok, so I really want to add the 3 pinball titles to Hyperspin (Future Pinball, Visual Pinball, and Pinball FX2). Can anyone PM me links to all the files required to do so? It'd be really appreciated. I know one of them (Visual Pinball, I think) had like 5 different versions of the emulator, how exactly would something like that work when setting it up in HS?
BATTLEDONKEY Posted May 4, 2017 Posted May 4, 2017 You would need to set up all the versions of visual pinball independently first, ie. Visual pinball 10, 9.x,8.x or whichever versions u plan to use. Create a database .xml of all the tables u have for all the different versions of visual pinball, then in rocketlauncherui you want to set the default version as the one u have the most tables for. So if majority of ur tables are vp9.x then set it as default n set the other versions as alternate emulators, finally u will need to associate which tables use the alternate emus by right clicking the tables from the roms tab and selecting either vp8.x or vp10 etc.
