Adding WIIMotes screws up menu control?
bacchuspup
Okay... so I used the Startup Script that's provided elsewhere on this site to get the Hyperspin Menu to work with my x360 controller.  It's been working fine.
Then I added WIIMote controllers to my computer through Bluetooth so I can play WII games through Dolphin.  Now my menu navigation is all screwed up.  When I get in to Hyperspin, the menus uncontrollably start scrolling, and neither the X360 inputs nor the keyboard inputs work.  Even using Task Manager to exit Hyperspin and taking the batteries out of the WIIMotes doesn't help when I restart Hyperspin.  I have to restart the computer without the WIIMotes turned on to get Hyperspin to work again.
Does anyone know how I can fix this?  Thanks in advance!
I had the same problem, I fixed it by changing one of the settings in the Startup Script.ini
It's been awhile so I don't remember exactly but I think I changed the number of joysticks from 4 to 1... Joysticks_MaxNumberOfJoysticks=1
Open the .ini file, if it's set to 4 try saving it as 1 n see if that fixes it
Wow... that completely and totally worked.  You're a lifesaver, donkey.  Which is not a sentence I ever suspected I'd say, but there you go.  Thanks so much!
