makhy14 Posted June 6, 2017 Posted June 6, 2017 after various problems i have two hyperspins installed on my two different pc for mamecab there is only one problem i cant choose.scroll up or down the games by letters in mame(i have only this emulator) with 29990 roms i can't choose the genre, i can navigate in the wheel menu-but when i hold right or left the joystick ,it shows to me a question mark (?) e i cant choose the letter i have downloaded also the last xml of mame 186 i m actually using a mame 32 144 and a mame 174 64bit and problem is on both the systems initially when i was setting up hyperspin i have not got this problem..
Avar Posted June 6, 2017 Posted June 6, 2017 Do you have "Use XML Indeces" set in HyperHQ for the wheel and does your xml copy have the jump point letters defined?
makhy14 Posted June 6, 2017 Author Posted June 6, 2017 yes it is set in hyperhq..the jump point i dont have any idea....
Avar Posted June 6, 2017 Posted June 6, 2017 I'm away from rig atm but if you ppost yours I can check it.
makhy14 Posted June 6, 2017 Author Posted June 6, 2017 this is the first i take it from database(mame ) MAME.xml
Avar Posted June 6, 2017 Posted June 6, 2017 Yeah so the problem is as expected. There's nothing indexed. To fix it, just go to the first game for each number and letter and set index = "true" and image ="<whatever the letter or number is>" So for 1, image = "1" and for q image ="q"
makhy14 Posted June 6, 2017 Author Posted June 6, 2017 while this is of the hyperspin with 29900 rom MAME.rar
Avar Posted June 6, 2017 Posted June 6, 2017 No problem. Yeah the latest mame ones can sometimes be missing them until the database team has a whack at it but at least it's an easy fix
makhy14 Posted June 6, 2017 Author Posted June 6, 2017 mmmh it is strange...the problem is unsolved there is the possibility that..if i jump one letter(then i made a new control) the jump letter is no function.. if u have time then could you pass a compled xml?
Avar Posted June 6, 2017 Posted June 6, 2017 I don't have 0.186 as I've just come from the Arctic where I wasn't unable to update MAME for some years due to the download size But here are examples: <game name="005" index="true" image="0"> <game name="1on1gov" index="true" image="1"> <game name="qberttst" index="true" image="q"> W/e the first game is for each letter, that's the one you index.
chillinwater Posted June 8, 2017 Posted June 8, 2017 also once your database is working make sure you press and hold your, "skip up" or "skip down" buttons while in a system wheel not the main menu wheel or is it the "skip up num" and "skip down num" buttons? cant remember then you can use your "up" "down" to cycle through the letters Game\Theme\Favorites\Genre - List Creation * FatMatch File Renaming for HyperNewbies. Like Me! https://hyperspin-fe.com/forums/topic/259-setting-up-un-official-systems-with-hyperspin/?do=findComment&comment=31034
