Magic-Engine and TurboEngine Emulators and DT virtual drive
DubaiShark
I have one problem also I couldn't find a fix for it I'm using magic PC Engine to ran PC Engine CD-ROMS but i couldn't run it through the Hyper something about the virtual drive I'm using DT lite and configured the hyper to it but still have the same problem any help with that I can run normal Roms because they don't need virtual drive this is different couldn't fine any tutorial about this in google "how to run PCengine CD Rom in HyperSpin" I know how to run it without Hyper Spin if u ask
When I run the game it return me back saying I have to tern virtual drive on even after I made the setup for it to DTAgent.exe
Mednafen has the ability to play these without a virtual drive I am pretty sure. Easy to setup too imho. I had too many issues with virtual drives and look to avoid them whenever possible. Good luck.
Sent from my SM-G920V using Tapatalk
Thanks for the info Mednafen is to complicated for me couldn't understand how to use it
Any chance how to use virtual drive in Magic PC Engine Emu using HyperSpin and not to use other emu
Someone else will need to chime in. I was not able to use a virtual drive at all on my setup, hence avoiding them at all costs. Good luck.
  • 4 weeks later...
I've also got issues with Magic Engine and Mednafen trying to convince them to load PC Engine CD games
Followed tips on what to set, but still no loading CD games via HyperSpin
Magic Engine works great with PC Engine games, but whines about virtual drive not installed. It is installed and set to the drive I intend to use via RocketLauncherUI settings correctly and pointing to wher DaemonTools is installed. Daemon Tools runs and works fine
Tried Mednafen, I can't even get it to run never mind try and load PC Engine CD games
At the moment I'm stumped and at a loss why PC Engine CD games refuse to load, I can load a CD game directly via Magic Engine but not via HyperSpin. It fails complaining virtual drive isn't set up but it is and is enabled in the RocketLauncherUI, so its bound to be something I haven't set correctly
