FBA issue losing sound
tm3812
Hi folks. Need help from the great team here at hyperspin.
I'm using FBA to make all of my Capcom games work. But i lose sound when the emu loads.
Now what's weird is that i can click Alt-Enter and the emu comes out of full screen mode and i then have sound.
Next when i exit back to the main wheel i don't have sound. i can only get the sound back if i exit out of Hyperspin all together and then re-enter.
I'm sure it's a simple problem that i'm over looking but thought i'd post my log to see if anyone else has had this issue.
thanks,
21:25:33:965 | HL |     INFO  | +N/A   | Main - HyperLaunch v3.0.1.0
21:25:33:965 | HL |     INFO  | +0     | Main - System Specs:
				HyperLaunch Dir: D:\Hyperspin\HyperLaunch
				OS: WIN_7
				Architecture: 64-bit (might not be accurate)
				OS Admin Status: No
				Monitor #1 (\\.\DISPLAY1): 1842x1036 (1842x1036 work)
				AutoHotkey Path: C:\Program Files\AutoHotkey\AutoHotkey.exe
				AHK Version: 1.1.09.04
				Unicode: No
21:25:33:965 | HL |     INFO  | +0     | Main - HyperSpin.exe coordinates are x0 y0 w1842 h1036
21:25:33:965 | HL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\HyperLaunch\HyperLaunch.exe exists
21:25:33:966 | HL |     INFO  | +0     | Main - HyperLaunch received "Capcom" and "ghouls"
21:25:33:972 | HL |     INFO  | +15    | Main - ghouls is using the default emulator: Final Burn Alpha
21:25:33:972 | HL |     INFO  | +0     | Main - Checking for a [Final Burn Alpha] section in D:\Hyperspin\HyperLaunch\Settings\Capcom\Emulators.ini
21:25:33:972 | HL |     INFO  | +0     | Main - Checking for a [Final Burn Alpha] section in D:\Hyperspin\HyperLaunch\Settings\Global Emulators.ini
21:25:33:972 | HL |     INFO  | +0     | Main - Found [Final Burn Alpha] in D:\Hyperspin\HyperLaunch\Settings\Global Emulators.ini
21:25:33:972 | HL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\Hyperlaunch\Modules\Final Burn Alpha\Final Burn Alpha.ahk exists
21:25:33:977 | HL |     INFO  | +0     | Main - CRC Check - CRC matches, this is an official unedited module.
21:25:33:977 | HL |     INFO  | +0     | Main - ghouls will use module: D:\Hyperspin\Hyperlaunch\Modules\Final Burn Alpha\Final Burn Alpha.ahk
21:25:33:989 | HL |     INFO  | +16    | Main - Using standard method with "Rom Extension" SkipChecks or without any SkipChecks.
21:25:33:991 | HL |     INFO  | +0     | Main - INI Keys read
21:25:33:992 | HL |     INFO  | +0     | CheckFile - Checking if c:\program Files\7-Zip\7zFM.exe exists
21:25:33:992 | HL |     INFO  | +0     | CheckFile - Checking if c:\program Files\7-Zip\7z.dll exists
21:25:33:993 | HL |     INFO  | +0     | CheckPaths - Started
21:25:33:993 | HL |     INFO  | +0     | CheckPaths - Found rom: D:\Downloads\CPS-1\ghouls.zip
21:25:33:993 | HL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\Emulators\FB Alpha\fba.exe exists
21:25:33:999 | HL |     INFO  | +0     | CheckPaths - Ended
21:25:33:999 | HL |     INFO  | +0     | BuildScript - User Variables:
				; INJECTED VARIABLES
				#NoTrayIcon
				#InstallKeybdHook
				DetectHiddenWindows, ON
				SetTitleMatchMode, 2
				SendMode, Event
				0 = 2
				frontendPID = 5884
				frontendPath = D:\Hyperspin
				frontendExe = HyperSpin.exe
				frontendExt = exe
				frontendName = HyperSpin
				frontendDrive = D:
				exitEmulatorKey = ~Esc
				exitEmulatorKeyWait = 0
				forceHoldKey = ~Esc
				restoreFE = Restore and Click
				exitScriptKey = ~q & ~s
				toggleCursorKey = ~e & ~t
				emuFullPath = D:\Hyperspin\Emulators\FB Alpha\fba.exe
				emuPath = D:\Hyperspin\Emulators\FB Alpha
				emuName = Final Burn Alpha
				emuExt = exe
				romPath = D:\Downloads\CPS-1
				romPathFromIni = D:\Hyperspin\Emulators\CPS3\Roms|D:\Downloads\CPS-1|D:\Downloads\CPS-2|D:\Hyperspin\Emulators\MAME0148\roms
				romExtension = .zip
				romExtensionOrig = .zip
				romExtensions = zip
				executable = fba.exe
				systemName = Capcom
				dbName = ghouls
				romName = ghouls
				romMapPath =
				romMappingEnabled = false
				romMappingMenuWidth = 300
				romMappingMenuMargin = 50
				romMappingTextMargin = 10
				romMappingMenuFlagWidth = 40
				skipchecks = false
				romMatchExt = false
				logFile = D:\Hyperspin\HyperLaunch\HyperLaunch.log
				logLevel = 3
				logIncludeModule = true
				logShowCommandWindow = false
				logCommandWindow = false
				navUpKey = Up
				navDownKey = Down
				navLeftKey = Left
				navRightKey = Right
				navSelectKey = Enter
				navP2UpKey = Numpad8
				navP2DownKey = Numpad2
				navP2LeftKey = Numpad4
				navP2RightKey = Numpad6
				navP2SelectKey = NumpadEnter
				originalWidth = 1842
				originalHeight = 1036
				dtEnabled = true
				dtPath = C:\Users\tony\games\DAEMON Tools Lite\DTLite.exe
				dtUseSCSI = false
				dtAddDrive = false
				emuIdleShutdown = 0
				hideCursor = true
				hideEmu = false
				hideFE = false
				fadeIn = false
				fadeInDuration = 500
				fadeInDelay = 0
				fadeInExitDelay = 0
				fadeOutExitDelay = 0
				fadeOut = false
				fadeOutExtraScreen = true
				fadeOutDuration = 500
				fadeOutDelay = 0
				fadeLyrInterpolation = 7
				fadeLyr1Color = FF000000
				fadeLyr2X = 300
				fadeLyr2Y = 300
				fadeLyr2Adjust = 1
				fadeLyr2PicPad = 0
				fadeLyr3Pos = Center
				fadeLyr3X = 300
				fadeLyr3Y = 300
				fadeLyr3Adjust = 0.75
				fadeLyr3Speed = 750
				fadeLyr3Type = imageandbar
				fadeLyr3Repeat = 1
				fadeLyr3PicPad = 0
				fadeLyr4Adjust = 0.75
				fadeLyr4X = 100
				fadeLyr4Y = 100
				fadeLyr4FPS = 10
				fadeLyr4PicPad = 0
				fadeTranspGifColor = FFFFFF
				fadeBarWindow = false
				fadeBarWindowX =
				fadeBarWindowY =
				fadeBarWindowW = 600
				fadeBarWindowH = 120
				fadeBarWindowR = 20
				fadeBarWindowM = 20
				fadeBarWindowHatchStyle = 8
				fadeBarBack = false
				fadeBarBackColor = FF555555
				fadeBarH = 20
				fadeBarR = 5
				fadeBarColor = DD00BFFF
				fadeBarHatchStyle = 3
				fadeBarPercentageText = false
				fadeBarInfoText = false
				fadeBarXOffset = 0
				fadeBarYOffset = 100
				fadeRomInfoDescription = text
				fadeRomInfoSystemName = text
				fadeRomInfoYear = text
				fadeRomInfoGenre = text
				fadeRomInfoRating = text
				fadeRomInfoTextMargin = 5
				fadeStatsInfoTextMargin = 5
				fadeText1X = 0
				fadeText1Y = 0
				fadeText1 = Loading Game
				fadeText2X = 0
				fadeText2Y = 0
				fadeFont = Arial
				fadeInterruptKey =
				detectFadeErrorEnabled = true
				fadeImgPath = D:\Hyperspin\Hyperlaunch\Media\Fade
				HLDataPath = D:\Hyperspin\HyperLaunch\Data
				HLMediaPath = D:\Hyperspin\Hyperlaunch\Media
				HLErrSoundPath = D:\Hyperspin\Hyperlaunch\Media\Sounds\Error
				modulesPath = D:\Hyperspin\Hyperlaunch\Modules
				moduleFullName = D:\Hyperspin\Hyperlaunch\Modules\Final Burn Alpha\Final Burn Alpha.ahk
				moduleName = Final Burn Alpha
				modulePath = D:\Hyperspin\Hyperlaunch\Modules\Final Burn Alpha
				moduleExtension = ahk
				moduleExtensionsPath = D:\Hyperspin\HyperLaunch\Module Extensions
				libPath = D:\Hyperspin\HyperLaunch\Lib
				7zEnabled = true
				7zPath = c:\program Files\7-Zip\7zFM.exe
				7zDllPath = c:\program Files\7-Zip\7z.dll
				7zExtractPath = D:\games
				7zExtractPathOrig =
				7zAttachSystemName = true
				7zDelTemp = false
				7zSounds = true
				mgEnabled = true
				mgKey = ~NumpadSub
				mgBackgroundColor = FF000000
				mgSidePadding = 0.2
				mgYOffset = 500
				mgImageAdjust = 1
				mgFont = Arial
				mgText2Offset = 70
				mgUseSound = true
				mgSoundfreq = 300
				mgExitEffect = none
				mgSelectedEffect = rotate
				mgUseGameArt = false
				mgArtworkDir = Artwork1
				hpEnabled = true
				hpKey = NumpadAdd
				hpBackToMenuBarKey = X|NumpadSub
				hpZoomInKey = C
				hpZoomOutKey = V
				hpHiToTextPath = D:\Hyperspin\Hyperlaunch\Module Extensions\HiToText.exe
				hpSaveStateKeyCodes = {F10 down}{F10 up}
				hpLoadStateKeyCodes = {F10 down}{F10 up}
				keymapperEnabled = false
				keymapperAHKMethod = External
				keymapper = xpadder
				xpadderFullPath = D:\games\Xpadder53\Xpadder.exe
				joyToKeyFullPath = D:\games\JoyToKey_en\JoyToKey.exe
				keymapperProfilePath = D:\Hyperspin\Hyperlaunch\Profiles\xpadder
				keymapperHyperLaunchProfileEnabled = true
				JoyIDsEnabled = false
				JoyIDsPreferredControllersSystem = Run'N' Drive Wireless|Logitech Driving Force Pro USB|T500 RS Gear Shift
				CustomJoyNamesEnabled = false
				CustomJoyNames = Run'N' Drive Wireless|Joystick\Logitech Driving Force Pro USB|Driving\T500 RS Gear Shift|gear shift
				FEProfile = D:\Hyperspin\Hyperlaunch\Profiles\xpadder\HyperSpin
				defaultProfile = D:\Hyperspin\Hyperlaunch\Profiles\xpadder\_Default
				systemProfile = D:\Hyperspin\Hyperlaunch\Profiles\xpadder\Capcom
				xPadderSystemProfile = D:\Hyperspin\Hyperlaunch\Profiles\xpadder\Capcom\_Default
				emuProfile = D:\Hyperspin\Hyperlaunch\Profiles\xpadder\Capcom\Final Burn Alpha
				romProfile = D:\Hyperspin\Hyperlaunch\Profiles\xpadder\Capcom\ghouls
				HyperLaunchProfile = D:\Hyperspin\Hyperlaunch\Profiles\xpadder\HyperLaunch
				blankProfile = D:\Hyperspin\Hyperlaunch\Profiles\xpadder\_Default\blank
				ahkFEProfile = D:\Hyperspin\Hyperlaunch\Profiles\AHK\HyperSpin
				ahkDefaultProfile = D:\Hyperspin\Hyperlaunch\Profiles\AHK\_Default
				ahkSystemProfile = D:\Hyperspin\Hyperlaunch\Profiles\AHK\Capcom
				ahkEmuProfile = D:\Hyperspin\Hyperlaunch\Profiles\AHK\Capcom\Final Burn Alpha
				ahkRomProfile = D:\Hyperspin\Hyperlaunch\Profiles\AHK\Capcom\ghouls
				ahkHyperLaunchProfile = D:\Hyperspin\Hyperlaunch\Profiles\AHK\HyperLaunch
				bezelEnabled = false
				statisticsEnabled = true
21:25:33:002 | HL |     INFO  | +16    | BuildScript - Loaded XHotkey Init.ahk scripts
21:25:34:002 | HL |     INFO  | +0     | BuildScript - Loaded Keymapper Init.ahk scripts
21:25:34:002 | HL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\HyperLaunch\Module Extensions\VA.ahk exists
21:25:34:004 | HL |     INFO  | +0     | BuildScript - Loaded HyperPause Init.ahk scripts
21:25:34:004 | HL |     INFO  | +0     | BuildScript - Loaded Statistics Init.ahk scripts
21:25:34:004 | HL |     INFO  | +0     | BuildScript - Loaded MultiGame.ahk scripts
21:25:34:004 | HL |     INFO  | +0     | BuildScript - Loaded User Functions Init.ahk script
21:25:34:004 | HL |     INFO  | +0     | BuildScript - Module:
				MEmu = Final Burn Alpha
				MEmuV = v0.2.97.23
				MURL = http://www.barryharris.me.uk/
				MAuthor = djvj
				MVersion = 2.0.1
				MCRC = A317CAA5
				iCRC =
				MID = 635038268890292583
				MSystem = "Final Burn Alpha","NEC TurboGrafx-16","NEC PC Engine","NEC SuperGrafx","Sega Mega Drive","SNK Neo Geo"
				; Notes:
				; You must have your roms renamed using clrmame and the dat generated by FBA. Run FBA manually and goto Misc->Generate dat file->Generate dat...
				; Open FBA manually and select MISC->Configure ROM paths... and define at least one path to your roms.
				; Fullscreen is now automatic when running FBA via command line
				; FBA supports 7z, so no need for hyperlaunch 7z functions
				StartModule()
				FadeInStart()
				If systemname in NEC TurboGrafx-16,NEC PC Engine,NEC SuperGrafx,Sega Mega Drive
				{	; The object controls how the module reacts to different systems. FBA can play a lot of systems, but the romName changes slightly so this module has to adapt
					mType := Object("NEC TurboGrafx-16","tg_","NEC PC Engine","pce_","NEC SuperGrafx","sgx_","Sega Mega Drive","md_")
					ident := mType[systemName]	; search 1st array for the systemName identifier mednafen uses
					If !ident
						ScriptError("Your systemName is: " . systemName . "`nIt is not one of the known supported systems for this FBA module: " . moduleName)
				fbaRomName := (If ident ? ident : "") . romName	; FBA requires an identifier prefix attached to the romName which tells FBA what system to run
				Run(executable . " """ . fbaRomName . """", emuPath)
				WinWait("ahk_class FB Alpha")
				WinWaitActive("ahk_class FB Alpha")
				; This loops detects the rom loading window and breaks when it's done. Only here to avoid using too many WinWait commands from all the odd flashing the emu does.
				Loop {
					IfWinActive, ahk_class #32770
						Break
					Sleep, 50
				; This loop detects when the emu window is done flashing back and forth between HS and the emu window and is actually in the game.
				Loop {
					If x = 10
						Break
					IfWinActive, ahk_class FB Alpha
						x++
					WinActivate, ahk_class FB Alpha
					Sleep, 50
				FadeInExit()
				FadeOutExit()
				ExitModule()
				CloseProcess:
					FadeOutStart()
					WinClose("ahk_class FB Alpha")
				Return
21:25:34:007 | HL |     INFO  | +0     | BuildScript - Loaded HyperPause scripts
21:25:34:007 | HL |     INFO  | +0     | BuildScript - Loaded MultiGame scripts
21:25:34:007 | HL |     INFO  | +0     | BuildScript - Loaded Statistics.ahk script
21:25:34:007 | HL |     INFO  | +0     | BuildScript - Loaded User Functions.ahk script
21:25:34:007 | HL |     INFO  | +0     | BuildScript - Finished injecting functions into module
21:25:34:007 | HL |     INFO  | +0     | Main - Module is built
21:25:34:007 | HL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\HyperLaunch\AutoHotkey.dll exists
21:25:34:008 | HL |     INFO  | +0     | Main - Hiding taskbar
21:25:34:218 | HL |     INFO  | +218   | Main - Hiding desktop
21:25:34:220 | HL |     INFO  | +0     | Main - Running module
21:25:34:380 | MD |     INFO  | +N/A   | Module initialized
21:25:34:382 | MD |     INFO  | +0     | Keymapper - Loading External AHK Keymapping
21:25:34:382 | MD |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\HyperLaunch\Module Extensions\AhkLauncher.exe exists
21:25:34:382 | MD |     INFO  | +0     | RunAHKKeymapper - Started
21:25:34:382 | MD |     INFO  | +0     | GetAHKProfile - Started
21:25:34:382 | MD |     INFO  | +0     | GetAHKProfile - Ended and found: D:\Hyperspin\Hyperlaunch\Profiles\AHK\_Default.ahk
21:25:34:382 | MD |     INFO  | +0     | Process - Exist AhkLauncher.exe
21:25:34:384 | MD |     INFO  | +0     | Run - Running: D:\Hyperspin\HyperLaunch\Module Extensions\AhkLauncher.exe -notray "D:\Hyperspin\Hyperlaunch\Profiles\AHK\_Default.ahk"
21:25:34:461 | MD |     INFO  | +78    | RunAHKKeymapper - Ended
21:25:34:462 | MD |     INFO  | +0     | StartModule - Started
21:25:34:463 | MD |     INFO  | +0     | StartModule - MEmu: Final Burn Alpha
				MEmuV: v0.2.97.23
				MURL: http://www.barryharris.me.uk/
				MAuthor: djvj
				MVersion: 2.0.1
				MCRC: A317CAA5
				iCRC:
				MID:
				MSystem: "Final Burn Alpha","NEC TurboGrafx-16","NEC PC Engine","NEC SuperGrafx","Sega Mega Drive","SNK Neo Geo"
21:25:34:463 | MD |  WARNING  | +0     | StartModule - You have an unsupported System Name for this module: "Capcom". Only the following System Names are suppported: ""Final Burn Alpha","NEC TurboGrafx-16","NEC PC Engine","NEC SuperGrafx","Sega Mega Drive","SNK Neo Geo""
21:25:34:463 | MD |     INFO  | +0     | Hiding mouse cursor
21:25:34:473 | MD |     INFO  | +16    | StartModule - Ended
21:25:34:473 | MD |     INFO  | +0     | StartGlobalUserFeatures - Starting
21:25:34:473 | MD |     INFO  | +0     | StartGlobalUserFeatures - Ending
21:25:34:474 | MD |     INFO  | +0     | Run - Running: D:\Hyperspin\Emulators\FB Alpha\fba.exe "ghouls"
21:25:34:501 | MD |     INFO  | +31    | CreateMGRomTable - Started
21:25:34:501 | MD |     INFO  | +0     | CreateRomTable - Started
21:25:34:501 | MD |     INFO  | +0     | CreateRomTable - Ended, 7 Loops to create table.
21:25:34:501 | MD |     INFO  | +0     | CreateMGRomTable - Ended
21:25:34:501 | MD |     INFO  | +0     | WinWait - Waiting for ahk_class FB Alpha
21:25:34:846 | MD |     INFO  | +343   | WinWaitActive - Waiting for "ahk_class FB Alpha"
21:25:41:415 | MD |     INFO  | +6568  | Process - WaitClose fba.exe
21:27:26:622 | MD |     INFO  | +105207 | WinClose - Closing: ahk_class FB Alpha
21:27:26:979 | MD |     INFO  | +359   | StopGlobalUserFeatures - Starting
21:27:26:979 | MD |     INFO  | +0     | StopGlobalUserFeatures - Ending
21:27:26:979 | MD |     INFO  | +0     | ExitModule - Started
21:27:26:979 | MD |     INFO  | +0     | Starting Updating Statistics:
21:27:26:036 | MD |     INFO  | +46    | Game section statistics updated.
21:27:27:036 | MD |     INFO  | +0     | RunAHKKeymapper - Started
21:27:27:036 | MD |     INFO  | +0     | GetAHKProfile - Started
21:27:27:036 | MD |     INFO  | +0     | GetAHKProfile - Ended and no profile found
21:27:27:037 | MD |     INFO  | +0     | Process - Exist AhkLauncher.exe
21:27:27:039 | MD |     INFO  | +16    | RunAHKKeymapper - Ended
21:27:27:039 | MD |     INFO  | +0     | ExitModule - Ended
21:27:27:039 | MD |     INFO  | +0     | End of Module Logs
21:25:34:224 | HL |     INFO  | +0     | Main - Starting timer to watch if Front End gets displaced and restore it if it does.
21:27:27:089 | HL |     INFO  | +112867 | Main - Module ended, exiting HyperLaunch normally
21:27:27:089 | HL |     INFO  | +0     | ExitScript - Started
21:27:27:457 | HL |     INFO  | +359   | SystemCursor - Restoring mouse cursor
21:27:27:463 | HL |     INFO  | +15    | ExitScript - Ended
  • 1 month later...
No replies? I can't believe someone doesn't know how to fix this. If it helps it hangs up with neo geo games too. Every time I use a button the emulator freezes. Is my module out of date or something? Or do I have the wrong emulator? Any help would be greatly appreciated.
Nope. Works like a champ. Also when I play neo geo games and hit a button the games freezes. And there isn't
anything I can do to fix that. But all games work great outside of hyperspin. I tried using different modules but that just caused hyperspin to freak out. So I just went with MAME. I like the graphics better with FBA but if it doesn't work right with hyperspin then it's not worth it. Thanks for the reply.
