Johno Posted June 16, 2017 Posted June 16, 2017 Hey Guys, i can't seem to get daphne singe to load American Laser Games inside of hyperspin/rocket launcher. I can load them outside of both by running the .bat file I have for each game but when I try to load them in hyperspin/rocket launcher I get an error "There was an error waiting for the window "Daphne ahk_class SDL_app". Please check you have the correct version emulator installed for this module" What am I doing wrong? Cheers Johno
Avar Posted June 16, 2017 Posted June 16, 2017 Are you trying to run the BAT? Or do you have the txt files setup as per the module instructions? At least I think that's what the module instructions say I'm not at home to check at the moment.
pinsanity Posted June 16, 2017 Posted June 16, 2017 If you have the games running properly through a bat file you can use the PCLauncher module to run each one instead of Daphne module. Use each game's bat file as an exe in the same way you would setup a PC game with an exe in Hyperspin.
Johno Posted June 17, 2017 Author Posted June 17, 2017 On 6/16/2017 at 12:03 PM, pinsanity said: If you have the games running properly through a bat file you can use the PCLauncher module to run each one instead of Daphne module. Use each game's bat file as an exe in the same way you would setup a PC game with an exe in Hyperspin. Expand sorry for my ignorance but how do I do this? When I want to load a pc game or program in hyperspin I use HyperHQ and just point to the .exe fie for that program. eg I run skjukebox and firefox (to listen to digital radio stations on the web) and I just point hyperhq to the skjukebox.exe and firefox.exe and run them that way. Is that not the way to do it? should I be using pclauncher? if so how do i use it?
pinsanity Posted June 17, 2017 Posted June 17, 2017 On 6/17/2017 at 12:52 AM, Johno said: sorry for my ignorance but how do I do this? When I want to load a pc game or program in hyperspin I use HyperHQ and just point to the .exe fie for that program. eg I run skjukebox and firefox (to listen to digital radio stations on the web) and I just point hyperhq to the skjukebox.exe and firefox.exe and run them that way. Is that not the way to do it? should I be using pclauncher? if so how do i use it? Expand You can use either way but I currently have mine set up through Rocketlauncher using the PCLauncher module. Just make sure that the bat file names for your ALG games match the database if you use HyperHQ so it knows what file to use.
pinsanity Posted June 17, 2017 Posted June 17, 2017 Okay mate, I have had a play around with it and now have ALG running through HyperHQ so it is more familiar to you. In HyperHQ go into the wheel settings for American Laser Games and change the settings so they look similar to this. The rom path is where your bat files for each game are located. They must match the database xml entries to work (crimepatrol, drugwars, johhnyrock, maddog etc) so rename them if you have to. After that it should work through the Hyperspin frontend. It will not run through Rocketlauncher as you are bypassing it in the HyperHQ settings
Johno Posted June 22, 2017 Author Posted June 22, 2017 thanks guys. got it working by running the .bat files directly. now i got my mayflash dolphin bar but I can't seem to get it to work with the american laser games and my wiimote no matter which mode I select. I can aim and the 'A" button seems to make the reload sound but I can't fire. I'm guessing mayube I need to remap the keys so does anybody know how to do this in daphne singe??
