zorrobandito Posted April 23, 2014 Share Posted April 23, 2014 I have an existing setup and want to freshen it using HyperSync. I followed the instructions, testing with a system I thought would have minimum download impact if things went awry. I went for the Nintendo 64 and I can see that HSS is pulling down new themes (great) and all the cart pics (not so great when I'm only missing a handful). I've looked for a "check for existing" setting but can't find it - what am I missing? If I did the same thing with MAME (which is my intent), my router would melt. Link to comment Share on other sites More sharing options...
rfancella Posted April 23, 2014 Share Posted April 23, 2014 I have an existing setup and want to freshen it using HyperSync. I followed the instructions, testing with a system I thought would have minimum download impact if things went awry. I went for the Nintendo 64 and I can see that HSS is pulling down new themes (great) and all the cart pics (not so great when I'm only missing a handful). I've looked for a "check for existing" setting but can't find it - what am I missing? If I did the same thing with MAME (which is my intent), my router would melt. HyperSync should only download what you are missing based on your database xml. Are all the paths correct? Are you using the default paths for all your artwork? (...\HyperSpin\Media\...) Thanks, Ron Link to comment Share on other sites More sharing options...
zorrobandito Posted April 24, 2014 Author Share Posted April 24, 2014 Thanks for the reply, Ron. The files appear to be in the right place. Carts = C:\Hyperspin\Media\Nintendo 64\Images\Artwork4 and my HSS setting is pretty minimal: C:\Hyperspin\Media\ What I did notice just then, though is that the new files are a bit larger. i.e. the standard dimensions on the old cart pics (from 2009) are 330x220 whereas the newer versions are 400x268. I'm guessing that HSS is picking up the improved versions. Since my cab is fairly lo-res (max 640x480), it would be nice if I could exclude these to save on bandwidth but still pick up the ones I am missing. Any thoughts or is that just getting too darn picky? Link to comment Share on other sites More sharing options...
