Sega Saturn SSF - Game Screen cutoff at bottom?
bzeeb
Followed @SIMPLYAUSTIN guide here: https://www.youtube.com/watch?v=5Lq6Zb3782Q
I have a EU copy of Guardian Heroes and Three Dirty Dwarves, and when I load them up it looks like the bottom part of the screen is cut off.  Is there some NTSC vs PAL setting or something I need to set so the resolution will be proper?  Or do I need non-eu versions of these games?
EDIT: I ended up swapping the area code in SSF Options to Europe and restarting it, last time I didn't restart it - that's why the bottom was getting cut off.
No. Set your Full Screen resolution to your exact desktop resolution. , then relaunch the game.
Open SSF and CTL+S or ALT+S can't exactly remember though.
Where would I tweak this?
Here's an example of what it looks like for me, you can see the H getting cutoff - it shouldn't.    This happens even if maximized (ALT+Enter)
I did open the ccd in an older copy of SSF and it worked fine.  So it some setting im missing here...
EDIT: See top post for solution
Also it looks a lot nicer,  SSF Beta 007 R5.  However it has trouble detecting xbox360  d-pad unlike the newer one.  How do I remove the smoothing to the graphics its trying to do (not as crisp lines etc).
EDIT: Unchecking Bilinear Filtering seemed to increase the sharpness of the pixels
