Griffindodd Posted April 26, 2014 Posted April 26, 2014 I have Daphne working fine outside of hyperspin, but when I launch it from within Hyperspin with Hyperlauncher 3 it insists on changing my screen resolution and it doesn't go back after quitting the game, so then my hyperspin menus are all hanging half off my screen. My hyperspin setup is default a 1920x1080, I would like to just run Daphne at this same resolution or be able to make sure it returns to back to 1920x1080 when it quits back to Hyperspin. MvC Revolution | Identity Crisis 51/32/29 | Little Ms. Pac-Man | Paperboy: Exclusive Edition
rfancella Posted April 26, 2014 Posted April 26, 2014 I have Daphne working fine outside of hyperspin, but when I launch it from within Hyperspin with Hyperlauncher 3 it insists on changing my screen resolution and it doesn't go back after quitting the game, so then my hyperspin menus are all hanging half off my screen.My hyperspin setup is default a 1920x1080, I would like to just run Daphne at this same resolution or be able to make sure it returns to back to 1920x1080 when it quits back to Hyperspin. Griffindodd, Set your screen resolution in HyperLaunchHQ. Select Modules on top. Select the Daphne.ahk and click the "Edit Global Module Settings". In that screen is your ScreenWidth and ScreenHeight. This will set your screen resolution. Give it a try and let us know. Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
Griffindodd Posted April 26, 2014 Author Posted April 26, 2014 perfect, thank you this worked MvC Revolution | Identity Crisis 51/32/29 | Little Ms. Pac-Man | Paperboy: Exclusive Edition
