OneBadVeggie Posted April 28, 2014 Posted April 28, 2014 I've just been messing with a few different emulators, and saw on a list that Makaron is better to us with Windows CE games on Dreamcast than Demul. My issue I'm having may just be a simple setup issue, I found all the files I need to run it I believe. I'm running GDI files, which as far as I know work with Makaron. My problem is when I go to use an image, I get an error: I haven't been able to find any solution online, so I want to see if anyone else knows what the issue might be.
hhgross Posted April 29, 2014 Posted April 29, 2014 I've just been messing with a few different emulators, and saw on a list that Makaron is better to us with Windows CE games on Dreamcast than Demul.My issue I'm having may just be a simple setup issue, I found all the files I need to run it I believe. I'm running GDI files, which as far as I know work with Makaron. My problem is when I go to use an image, I get an error: [ATTACH=CONFIG]40652[/ATTACH] I haven't been able to find any solution online, so I want to see if anyone else knows what the issue might be. I've been setting up makaron recently as well and having a ton of errors to work through. I finally got it working... For the most part. Try setting your resolution to 640x480 in your makaron.ini. If that doesn't work, I'll try and think of something else, I was getting a ton of those errors as well. Maybe try turning off multi threading in the ini. Set it to zero. I've also found that you get a d3d error if you don't exit properly using f8 to exit the game, and alt+f4 to exit the emu
hhgross Posted April 29, 2014 Posted April 29, 2014 Also, take a look at this thread. You might have an old version of the emu. http://www.hyperspin-fe.com/forum/showthread.php?23777-Cant-get-Makaron-T12-5-to-work-at-all
