voicon Posted September 2, 2017 Posted September 2, 2017 Hi All I started this build 2 years ago but due to illness I had to put it on hold, not much has changed in my build but I am looking at getting a new GFX card, most of the questions I have seen on this were before the 10xx series cards were released. I have a i7 3770 CPU with 16Gb of 1600Mhz RAM What minimum amount I can spend on a card that will do the job, is it worth getting a 10xx or saving money and go for an older card? Thanks in advance.
AYOOOB Posted September 5, 2017 Posted September 5, 2017 my setup is similar to yours the difference is i have i7 4770K and same gb ram but with different clock speed my setup is i7 4770K 16gb ram 2133Mhz GIGBYTE Nvidia Geforce 750Ti the graphic cards run all the games and emulators with no issues and its really cheap nowdays i can even run Nesica Dumps with no problem so my suggestion is to go with 750Ti unless you have the money to get a 10xx GPU
voicon Posted September 5, 2017 Author Posted September 5, 2017 Thanks, I found a deal on a 1050 today for £90 which for the UK is cheap. Will see how it performs when it arrives.
