could not locate this file
fheratus
ScriptError - Your LibRetro_SNES dll is set to bsnes_balanced_libretro but could not locate this file:
D:\hyperspin133\Emulators\RetroArch\cores\bsnes_balanced_libretro.dll
this  is the error i get if i launche game on rocket ui but on retroarch it lauches good please help .
ok so how do i do that ? sorry still new to this and trying to set this up for my son and this has bin my first wall i hit.
i got mame and nes working but this has bin harder snes :) oh and thank you for replying so fast :)
Either open up retroarch and download the bsnes_balanced core from the online updater section, or if u prefer to use a different core for snes I.e. snes9x then u have to open up rocketlauncherui, on the right side click the snes system tab, then along the top click the modules tab, then under retroarch module settings there is a setting to fill in the info of the core u want to use. Read the help bubble and it explains what needs to be filled in the field for it to use a different core
ok now it gives this error and game dont launch on retroarch or rocketui. ScriptError - Could not find "A.S.P. - Air Strike Patrol (USA)" inside the archive with any defined Rom Extensions. Check if you are missing the correct Rom Extension for this rom for RetroArch's Extensions, enable Rom_Match_Extension, or correct the file name inside the archive.
got it to work thank you all for your help you guys are awesome :)
