Mednafen AHK sound buffer editing
coincoincoincoin
hi folks,
So i had problems with mednafen sound and i noticed that editing sound.buffer.time to 200ms fixed the issue, but...
when i launch from HL, the setting seems to be forgotten
I had the same problem with the video driver, but hyperlaunchHQ allow me to choose it directly... but i can't find a way to choose the sound.buffer.time
I will probably must edit a command line somewhere in the AHK but i just can't find a "RunEmu" line, so...
Hope you can help me
Come on you guys please help me cause that mednafen is a p*** in the a** to set up
Video driver sdl is sometime cancelled, especially for the lynx emulation
and it also seems to me that the resolution settings are not ok for pcengine
Do you guys get it with that mednafen stuff?
You could try turning off HyperLaunch for systems you use Mednafen for and change settings in mednafen-09x.cfg manually. That way the HyperLaunch script won't reset any settings you change.
thx for the help, but i fixed it by myself...
For archiving, the problem as nothing to deal with sound.buffer, it still a problem about video.driver
In fact, when i updated default mednafen ahk in HLHQ, it didn't work for lynx games (dunno why), only for the pce games
So i had to set lynx specific ahk video driver on SDL, instead of letting it on default (even if default was set on sdl)
looks weird, but it worked for me
