dazzlaa Posted November 13, 2017 Posted November 13, 2017 Hi all, is there a guide for how to properly set up FP for hyper Spin? I can open future pinball and load table and it works great but when I use rocket launcher ui I get errors and the table is unplayable. i popped all my tables and associated files right into the future pinball "tables" folder and used that as my Rom location. felling pretty lost :/ thanks
Bungles Posted November 13, 2017 Posted November 13, 2017 I will keep an eye on this post also as I have had it working in the past but then all went to hell for some reason. Now I can load the tables fine through the Main App ok but BAM FPLoader is not working with the Future PInball Module in RL. You will find there is information remarks within the ahk file which I will run through and keep tinkering and if I get a result will post it. ;---------------------------------------------------------------------------- ; Notes: ; Thanks to the FPLaunch author for some of the code ; To set fullscreen, open the emu and goto Preferences->Video / Rendering Options and set your resolution and check fullscreen. ; To prevent crashes disable "Load Image into Table Editor" under Preferences->Editor Options ; AHK is not 100% reliable with its focusing. If coin/start/flipper buttons don't function when you start a table, try clicking your left mouse button. ; The script will fail If you have any errors or missing files for your tables. Make sure every table is working before you turn on the LoadingScreen. ; If you use Esc as your exit_emulator_key, you may see the table editor flash in when you exit a game. This is because Esc is the default fixed key for FP so it's closing the game before ahk does. ; If you get script errors or no tables seem to work, try running FP as admin and it will probably fix it. ; If you need to run FP as admin, you can try this trick http://www.zdnet.com/blog/bott/fixing-windows-vista-part-2-taming-uac/436?pg=4 and use the other Run command commented below ; Future Pinball stores its config in the registry @ HKEY_CURRENT_USER\Software\Future Pinball\GamePlayer ; For tables with custom game rooms you can see the fine details by pressing F11 to enable manual camera, then using WASD and your mouse to move around. Press F1 through F5 to cycle the camera views. ; If you are using BAM together with Future Pinball, make sure you point your emulator executable to the FPLoader.exe file and do not rename this file to anything else. ; You can download BAM here : http://www.ravarcade.pl/ ; ;Fade: ;If you want to hide the future pinball loading screen behind fade, you just need to set the fullscreen option to false. ;---------------------------------------------------------------------------- Retro Cafe - Universal ThemeHyperControl - Main Menu Config and Apps WheelAudiocade - Main Menu Music PlayerTelltale Games WheelPCGamers Top 100 PC Games 2014 WheelMGS HD Exit Screen8-Bitdo Special ArtAll Contributions My Youtube Channel - https://www.youtube.com/user/3ungle
dazzlaa Posted November 14, 2017 Author Posted November 14, 2017 On 13/11/2017 at 7:35 AM, Bungles said: I will keep an eye on this post also as I have had it working in the past but then all went to hell for some reason. Now I can load the tables fine through the Main App ok but BAM FPLoader is not working with the Future PInball Module in RL. You will find there is information remarks within the ahk file which I will run through and keep tinkering and if I get a result will post it. ;---------------------------------------------------------------------------- ; Notes: ; Thanks to the FPLaunch author for some of the code ; To set fullscreen, open the emu and goto Preferences->Video / Rendering Options and set your resolution and check fullscreen. ; To prevent crashes disable "Load Image into Table Editor" under Preferences->Editor Options ; AHK is not 100% reliable with its focusing. If coin/start/flipper buttons don't function when you start a table, try clicking your left mouse button. ; The script will fail If you have any errors or missing files for your tables. Make sure every table is working before you turn on the LoadingScreen. ; If you use Esc as your exit_emulator_key, you may see the table editor flash in when you exit a game. This is because Esc is the default fixed key for FP so it's closing the game before ahk does. ; If you get script errors or no tables seem to work, try running FP as admin and it will probably fix it. ; If you need to run FP as admin, you can try this trick http://www.zdnet.com/blog/bott/fixing-windows-vista-part-2-taming-uac/436?pg=4 and use the other Run command commented below ; Future Pinball stores its config in the registry @ HKEY_CURRENT_USER\Software\Future Pinball\GamePlayer ; For tables with custom game rooms you can see the fine details by pressing F11 to enable manual camera, then using WASD and your mouse to move around. Press F1 through F5 to cycle the camera views. ; If you are using BAM together with Future Pinball, make sure you point your emulator executable to the FPLoader.exe file and do not rename this file to anything else. ; You can download BAM here : http://www.ravarcade.pl/ ; ;Fade: ;If you want to hide the future pinball loading screen behind fade, you just need to set the fullscreen option to false. ;---------------------------------------------------------------------------- Thanks for the info you shared. I have got over my issue at the moment it seems by making the .exe file always open as administrator and removing all UAC account prompts within windows. The tables are now loading again.
