Exit Emulator Hotkey Issues
Quattro
I'm trying to figure out why pressing P1Start and P2Start at the same time in any emulator causes the game to exit back to Hyperspin. I've posted my Global RUI settings and my HyperHQ settings below. P1Start is assigned to 1 and P2Start is assigned to the 2 key. I keep searching in my settings and cannot find any place where it has 1+2 as an exit combination. I'm using two Ultrastik 360s and an IPAC2 for my buttons, so two different controllers are being used. Because of this I'm using the Hyperspin Startup Script. I've checked within HSS ini and can't find any setting that would suggest 1 and 2 combined serve as an exit.
Another minor issue is I cannot get a combination exit hotkey to work. I'd like to have my P1Coin + P1Start be an exit key rather than holding P1Coin for 2.5sec like it is now. P1Start is assigned to key 1 and P1Coin to key 3. I believe I set up the hotkey correctly in RUI, but when I try to make Exit in HyperHQ set to 3 + 1, HyperSpin Startup Script throws an error which I've provided a screenshot of.  It doesn't seem to like having two keys assigned to Exit in HyperHQ.
It'd be better to ask on the rlauncher.com forum, as the devs might be able to give you some insight.
You might check out the settings in the emulator itself. If you're using MAME, check out what's going on in the menu for that (Tab key by default toggles the menu).
