FIRST GAME LAUNCH IS VERY SLOW, SUBSEQUENT LAUNCH ARE FINE
blaaze3
Hi
I'm running Hyperspin on Windows 7 in conjunction with Rocketlauncher, everything works fine, BUT the very first ROM I attempt to execute (regardless of the system - MAME or others) always takes a very loooooong time to load - sometimes 20 seconds or longer. I hit the start button -- and Hyperspin just sits idle for a lengthy period -- and then all of a sudden, Rocketlauncher takes over (as expected) and boots the ROM. The funny thing is -- this only happens the very first time I launch a ROM. After I launch the first ROM, exit back to HS, and launch other ROMs, everything works as expected (i.e., no delays whatsoever).
Granted, this is a minor annoyance, but I'd like to eliminate the delay if its possible.
Initially, I thought the delay might be caused by Windows processes loading in the background during the boot process, but I've ruled this out. The delay always occurs when I boot the first ROM -- even if I allow Windows to fully boot and wait an extended period of time (e.g., an hour) before executing Hyperspin.
I also explored the possibility that the delay might be caused by Windows Defender, but I turned off Defender and the problem persists.
I guess this could be some sort of focus issue, but I really don't understand why this delay only occurs the first time I boot a ROM? Or perhaps Rocketlauncher runs through some initial checks/audits the very first time it is executed (but not subsequently) Or it creates a files on every first start and once its done its fine
Any suggestions would be very much appreciated.
Thanks for trying to help me,  it was set on «error» and i did turned it off, but unfortunatly i still have the same issue. I also turned off windows defender, but no luck still same issue when starting my first game which takes around 15-20 seconds to load. Once i launched the very first game, subsequent loads are instantanious. So it must be generating a file or scanning something on the first launch that takes 15-20 seconds. Its just very annoying since i am using it in my arcade cabinet that i built from scratch. If i can make this work, my cabinet will be completed, this is the only issue i still have to figure out. Any more help would be more than appreciated, thanks in advance. Also i have nothing install other than win 7 on this pc, everything is turned off, no anti-virus nothing. So it has to be related only to rocketlauncher / Hyperspin
****SOLVED****
I updated my HDD driver, problem solved. Lesson of the day, always keep your driver up to date, thanks for your help
