Demul Exit Key
Lamaman1971
Hi Folks, turned my attention back to Demul and can already see that quitting the emulator might be a problem. Is there any way to exit Demul using Escape? or should I use AHK to map ALT-F4?
DEmul should make use of escape by default. Are you running it out of RocketLauncher?
Thanks Griffin - it was my understanding of RocketLauncher that was at fault, slightly complicated by the stupid Demul module's approach of over writing the pad.ini controls until you transpose them into the module. POS. I set the escape key up in RocketLauncher no worries - its not Demul that handles that but rocketlauncher itself - or at least on the build Im using.
Cheers
Mark
