ftp folders not showing up
pd10101
when i log in i just get a "\"...........................?
i try to click on it and nothing happens. i put my usename, password, host, port in correctly. it logs in but nothing happens. wtf!
Status: Resolving address of ftp.hyperspin-themes.com
Status: Connecting to 209.159.145.244:21...
Status: Connection established, waiting for welcome message...
Response: 220---------- Welcome to Pure-FTPd [privsep] [TLS] ----------
Response: 220-You are user number 1 of 50 allowed.
Response: 220-Local time is now 08:39. Server port: 21.
Response: 220-This is a private system - No anonymous login
Response: 220-IPv6 connections are also welcome on this server.
Response: 220 You will be disconnected after 10 minutes of inactivity.
Command: USER [email protected]
Response: 331 User [email protected] OK. Password required
Command: PASS **********
Response: 230 OK. Current restricted directory is /
Command: SYST
Response: 215 UNIX Type: L8
Command: FEAT
Response: 211-Extensions supported:
Response: EPRT
Response: IDLE
Response: MDTM
Response: SIZE
Response: MFMT
Response: REST STREAM
Response: MLST type*;size*;sizd*;modify*;UNIX.mode*;UNIX.uid*;UNIX.gid*;unique*;
Response: MLSD
Response: AUTH TLS
Response: PBSZ
Response: PROT
Response: TVFS
Response: ESTA
Response: PASV
Response: EPSV
Response: SPSV
Response: ESTP
Response: 211 End.
Status: Server does not support non-ASCII characters.
Status: Connected
Status: Retrieving directory listing...
Command: PWD
Response: 257 "/" is your current location
Command: TYPE I
Response: 200 TYPE is now 8-bit binary
Command: PASV
Response: 227 Entering Passive Mode (209,159,145,244,49,21)
Command: MLSD
Response: 150 Accepted data connection
Response: 226-Options: -a -l
Response: 226 13 matches total
Status: Directory listing successful
Response: 220-You are user number 2 of 50 allowed.
Status: Connected
Status: Starting download of /index.html
Command: CWD /
Response: 250 OK. Current directory is /
Command: PWD
Command: TYPE A
Response: 200 TYPE is now ASCII
Command: PASV
Response: 227 Entering Passive Mode (209,159,145,244,39,13)
Command: RETR index.html
Response: 226-File successfully transferred
Response: 226 0.000 seconds (measured here), 35.30 Mbytes per second
Status: File transfer successful, transferred 1,774 bytes in 1 second
Command: PASV
Response: 227 Entering Passive Mode (209,159,145,244,35,227)
Response: 226 0.000 seconds (measured here), 45.68 Mbytes per second
Status: File transfer successful, transferred 2,010 bytes in 1 second
Status: Starting download of /desktop.ini
Command: TYPE I
Command: PASV
Response: 227 Entering Passive Mode (209,159,145,244,234,236)
Command: RETR desktop.ini
Response: 226 0.000 seconds (measured here), 8.95 Mbytes per second
Status: File transfer successful, transferred 282 bytes in 1 second
Command: CDUP
Command: PWD
Hello,
Please this this post on the FTP:
http://www.hyperspin-fe.com/forum/showthread.php?30079-Ftp-access-must-read
Also, when posting to the forums, please use the code tags as described here:
http://www.hyperspin-fe.com/forum/showthread.php?31072-The-HyperNoobie-Guide-For-Posting-To-The-Fourm
Thank you,
Ron
"okay" i searched all posts, stickys and faq's. nothing helps the fact that when i attempt to log on all i get is "\" in the remote site box on filezilla. when i click on that box it gives me 8-9 files, 2 of them are internet websites that say something about china with coordinates........which seem like a virus, a read me file that is out of date, a desktop ini that doesnt do jack and couple more that i have no idea what they are.
I NEED HELP
I NEED HELP
Hello,
Check you setting. Your logs show "Status: Resolving address of ftp.hyperspin-themes.com" and you are using port "Response: 220-Local time is now 08:39. Server port: 21." As clearly stated in the first link I sent you, port 221 and the host address is "files.hyperspin-fe.com".
So, Please read the sticky. Check your settings and try again.
Thanks,
Ron
