Games fail to launch
kamal318
I tried to add nintendo Famicom system to rocket launcher subsequently to HyperSpin. I succeeded in auditing and adding the games and emulator to Rocket launcher. The games are being displayed in Hyperspin, but unable to launch. Plz help. Thanks
Guest hellsing001
Have you set the roms folder in HyperHQ for the NES Wheel and added either zip or nes to the filename field.
hellsing
Guest hellsing001
can you post a screen shot of hyperHQ nes screen.
Do the games load in rocketlauncher?
You can do a test after you audit the games using the rocket icon.
hellsing
Guest hellsing001
Extensions - add zip or nes in there.
Guest hellsing001
post a screenshot of your roms folder + hyperHQ again showing what you put extensions.
Guest hellsing001
unless he's put Zip instead of zip - or NES instead of nes - that's why I asked for a screenshot as another user put cue in the extension and it should have been CUE.
hellsing
Guest hellsing001
ok - lets try this. In rocketlauncherUI have you set this up. Screenshot attached.
Guest hellsing001
Also in the Hyperspin setting folder - find the setting file. Open it and you should have the following
[Main]
Menu_Mode=multi
Single_Mode_Name=MAME
Enable_Exit_Menu=true
Enable_Exit=true
Exit_Default=yes
Exit_Action=exit
Version=1.0.0.0
Last_System=MAME
Hyperlaunch_Path=C:\Emulation\RocketLauncher\RocketLauncher.exe - This is the important part. Make sure the path is correct for your system.
hellsing
Now i edited the settings.ini file as above. I have attached the screenshots of rockerlauncherUI and hyperHQ. Still it is not working. Plz advise.
