1 wheel with mame & model 2 on same wheel?
Martin0037
Hi guys.   This may have been asked before but I can’t seem to find anything definitive for exactly what I’m trying to do so here goes...
I’ve only ever had mame on my system .  1 wheel, loads of games (just mame)   I’ve just sort of got model 2 running on it but I only want maybe about 6 model2 games
Is there a way I can have just 1 wheel as before with both mame & model 2 games on together?  As now I have obviously a main menu wheel with mame and model 2 on
thanks.
basically what you want to do is use the alternative emulator thing in RL... if you're using RL. just add model 2 as the alternative emulator for the model 2 games you want. the process would be something like merge the mame xml and model 2 xml... then add the games in RL... setting up the alternative emulator. maybe someone else can do a step by step detailed response if you're still not sure how to do it.
Hi , you can use hyperxmlspin to merge systems , genre or anything else to create a wheel . it takes just five minutes.
Just watched it.  Gonna need to watch this quite a few more times I think.
Does this have to run in the background?  Or do you just use it once to create a xml so model 2 games will appear in mame wheel?
You Can use or as an application just to create your custom XML that will create automaticly your new wheels. First : you have to create à dedicated new main wheel with 2 systems , then you create 2 genres for each system into this main wheel
