Help with Graphiccard HDMI/Analog Output
HDRR
Hi everyone! I am using a SEGA Naomi Cabinet with a PC and Hyperspin).
I am using the original CRT Screen of the Naomi (640x480). It is plugged to my Graphiccard with the Analog Cable. Works finde.
My Graphiccard also has 2 HDMI Outputs. I wanted to use one of them to plug in a ELGATO HD 60 S to stream live from my Arcade Cabinet.
The Problem is, as soon as I plugin the HDMI Cable, the resolution jumps to 1920x1080 and I cant change it. I also cant use the CRT as a second desktop.
Anyone an idea how to use the CRT as "normal" Screen and just double the signal to the HDMI Output?
Thanks!
  • 2 months later...
well i dont know much about but capture cards, but i do know that u cant connect  both analog and digital output at the same time, so maybe thats the problem, 2 digital outputs works fine. so maybe thats the problem.
