Tron0091 Posted May 8, 2014 Posted May 8, 2014 First off amazing program and countless hours of fun setting up and playing. I seem to come across an issue when i edit Hyper HQ > Wheel Settings>Nav Themes>Wheel filters>roms only checked on. Because obviously I only want to see the games I have loaded. However, when ever i check this box i.e in Super Nintendo or Mame when I launch HyperSpin and go to select Super nintendo Hyper Spin just closes. any ideas would be appreciated.
KMxRetro Posted May 8, 2014 Posted May 8, 2014 This might be a silly question, but have you got the ROM path set in HyperHQ for those systems?
Tron0091 Posted May 8, 2014 Author Posted May 8, 2014 More like silly me. Didnt realize you had to path it in HQ as well as I have been running games fine before attempting tweaking things with HQ. Now that I have filled in the rom path with my roms and the executable with my emulator (I assume that is correct) however now in Hyper Spin wheel when I click on Super Nintendo all it seems to do is refresh instead of going to the roms wheel.
Tron0091 Posted May 9, 2014 Author Posted May 9, 2014 Ok so solved that by filling out the extensions. I can only assume that now my executable path is wrong. Because now it cannot find Hyperlaunch.exe. Even when I now uncheck the roms only it still has the error. Despite it working fine before attempting to edit HyperHQ. NOOB problems Maybe if there was a sticky dedicated to the HyperHQ setup I could try that but cant seem to find.
rfancella Posted May 9, 2014 Posted May 9, 2014 Tron0091 said: Ok so solved that by filling out the extensions.I can only assume that now my executable path is wrong. Because now it cannot find Hyperlaunch.exe. Even when I now uncheck the roms only it still has the error. Despite it working fine before attempting to edit HyperHQ. NOOB problems Maybe if there was a sticky dedicated to the HyperHQ setup I could try that but cant seem to find. Hello and Welcome to the Forums!!! Keep in mind also, separate multiple extensions with a comma. Also, if your rom extensions are both upper and lower case, put them both in, it's case sensitive. Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
Tron0091 Posted May 9, 2014 Author Posted May 9, 2014 Thanks rfancella I did solve the rom extension issue. But seem to have created an issue with HyperLaunch.exe. Now it says cannot find HyperLaunch.exe. I know it must have to path it in Hyper HQ somewhere now too. (As it was all working fine before i started to edit Hyper HQ). Turns out I had to check the execution to normal. It was default to HyperLaunch. Seem to work OK now. Thanks.
rfancella Posted May 9, 2014 Posted May 9, 2014 Tron0091 said: Thanks rfancella I did solve the rom extension issue. But seem to have created an issue with HyperLaunch.exe. Now it says cannot find HyperLaunch.exe.I know it must have to path it in Hyper HQ somewhere now too. (As it was all working fine before i started to edit Hyper HQ). Turns out I had to check the execution to normal. It was default to HyperLaunch. Seem to work OK now. Thanks. If you are getting that error, you changed the execution to normal, it's not using HyperLaunch or any of your HyperLaunchHQ settings. You only need to make one minor change and set it back to HyperLaunch. See here: http://www.hyperspin-fe.com/forum/showthread.php?33201-Launching-a-game-quot-Could-not-find-hyperlaunch-exe-quot&p=310032&viewfull=1#post310032 Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
