smappy Posted May 10, 2014 Posted May 10, 2014 Everything was working fine, then suddenly when I hit enter to load the rom, nothing happens. I remapped the load key from Enter to 1 with the same results. I can use the same key to exit hyperspin, so its not the keyboard. I decided to update mame to .153 just in case something in mame got corrupted and mame loads fine. not sure why its doing it or how to fix it.
rfancella Posted May 10, 2014 Posted May 10, 2014 Everything was working fine, then suddenly when I hit enter to load the rom, nothing happens. I remapped the load key from Enter to 1 with the same results. I can use the same key to exit hyperspin, so its not the keyboard.I decided to update mame to .153 just in case something in mame got corrupted and mame loads fine. not sure why its doing it or how to fix it. Smappy, Hello and welcom to the forums!! Here is a good post to start with. How to post to the forums: http://www.hyperspin-fe.com/forum/showthread.php?31072-The-HyperNoobie-Guide-For-Posting-To-The-Fourm It talks about posting logs (please use code tags as described) when asking for help. Please post your HyperSpin logs and try to launch a game in HyperLaunchHQ. Three good troubleshooting steps everyone should start with. 1). Does the game run from within the emulator only? 2). Does the game launch from HyperLaunchHQ? 3). Does the game launch from HyperSpin? Hope this starts you in the right direction. Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
