Noumenon Posted May 12, 2014 Posted May 12, 2014 I launch Nestopia with hyperlaunch and everything is working fine but the bezels don't show up in nestopia. I know that the bezels are loading because when I alt+tab the bezel is there loaded but it is no showing on top of the emulator as it should. I tried every options for the bezel in hyperlaunch and changed some things in the nestopia.ahk for the bezel to show but nothing has worked.
knewlife Posted May 12, 2014 Posted May 12, 2014 I have nestopia working with bezels... Mmn when i get home i can send you the module i use... I remember i have to manualy disable status bar and menu in emulator config cause the bezel code don't do it automatically Sent from my Nokia Lumia 520 using Tapatalk EmuLink (Canal de Youtube) | Main Menu Changer | HyperArchiver Version 0.0.0.17 | HSBezel
Noumenon Posted May 13, 2014 Author Posted May 13, 2014 I have nestopia working with bezels... Mmn when i get home i can send you the module i use... I remember i have to manualy disable status bar and menu in emulator config cause the bezel code don't do it automatically Sent from my Nokia Lumia 520 using Tapatalk Thank you man you have no idea how much that would help me. I have just about given up to get bezels working with nestopia.
rfancella Posted May 13, 2014 Posted May 13, 2014 I have nestopia working with bezels... Mmn when i get home i can send you the module i use... I remember i have to manualy disable status bar and menu in emulator config cause the bezel code don't do it automatically Sent from my Nokia Lumia 520 using Tapatalk Bezels are not supported in the official module. If you have it working, please post the module. Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
knewlife Posted May 13, 2014 Posted May 13, 2014 https://www.dropbox.com/s/zjtzlm84ftrrutt/Nestopia.zip Here you go... the bezel is not perfect, as i say, you must disable menu and status bar in the emulator settings, also you can see an small part of the window borders... but here you go... it also has other changes i made. For my this is the best emulator for NES, (not famicom... it will fail with many japanese games), has many options and the graphics are so fluid and natural. A shot: https://www.dropbox.com/s/ewcd9xcoxf6t9ok/20140513122653.png EmuLink (Canal de Youtube) | Main Menu Changer | HyperArchiver Version 0.0.0.17 | HSBezel
