whats the cause of lag with flash player on older pcs
relic
http://scratch.mit.edu/discuss/topic/9663/
http://forum.r2games.com/showthread.php?81779-Lag-Fixes-(some-you-may-not-have-seen-even!)
http://www.hyperspin-fe.com/forum/archive/index.php/t-26902.html
http://www.hyperspin-fe.com/forum/archive/index.php/t-24933.html
http://www.softwarepatch.com/tips/flash-errors-fix.html
read this its very intresting
where can i get the hyperspin fowarder
djvj
07-22-2013, 01:38 AM
I made a HyperLaunch Forwarder for older HS versions. You can find it on dropbox under the "HyperLaunch Forwarder" folder.
Read the included readme.txt for instructions on how to use.
mesk
08-15-2013, 12:52 AM
I have also noticed multiple Hyperspin.exe processes running. I do not think it is closing properly sometimes.
Same here.Sometimes I have to kill it via process explorer to be able to launch it again.This only happens with HS 1.3.2
EDIT: Can confirm no more HS.exe hanging after downgrading from 1.3.2 to 1.3.1.Thanks for the forwarder,djvj :)
sig.png 100%
Regarding the hyperspin issue where processes are orphaned, I discussed this in this other thread:
http://www.hyperspin-fe.com/forum/showthread.php?34554-Hyperspin-doesn-t-start-leaves-stuck-process&p=320554#post320554
The solution was to create a batch file to launch HyperSpin (instead of running HyperSpin.exe):
- create a batch file (e.g. StartHyperSpin.bat) and place it in the HyperSpin root directory
- put these two lines inside of it:
taskkill /im /f HyperSpin.exe
start /d "c:\path\to\your\HyperSpin" /b HyperSpin.exe
The first line issues a task kill to force killing any orphaned HyperSpin.exe processes and the second line forks a new HyperSpin.exe process.
So you should basically see a terminal popup and exit immediately when you run this and HyperSpin should launch a second later :o).
What I did on my system was adding a shortcut to this batch file to my User's StartUp folder. You can even change the shortcut so that it looks more like the native HyperSpin.exe binary (just change the icon and browse for icons in your HyperSpin.exe).
Hope this helps!
