defre1976 Posted October 3, 2018 Posted October 3, 2018 hi , i really like hyperspin , WII, WIIU , teknoparrot , sega model 2 , supermodel 3 , mame , retroarch , psp , ps2 all up and running . Buuuuuuuuuuuuuut the problems are the controls . I don't have an arcade cabinet or so . Hyperspin is running on a pc beside my tv . What i want is 2 xbox controllers , G25 wheel and 2 dolpinbars connected in one time . And its really difficult to get this running all at the same time . For example , i connect 2 xbox controllers together with my g25 wheel . Windows will then see First xbox controller in position 1 , g25 wheel in position 2 and my second xbox controller in position 3 . Really difficult to set this up for example supermodel 3 . Other problem is i have 2 dolphinbars , i bought this because i was thinking for the shooting games i will put the bar in Mode 2 and play the shooting games like this . But the issue here is when i put the 2 dolpinbars in mode 2 i can perfect move the 2 mouse pointers . From the moment i do this the mouse pointers are flickering pffff , also ingame the crosshair are flickering . And its not the position from the dolphinbars , i put 1 up and 1 down . Both set correct with the switch behind the bar . With succes i finally got it working in mode 4 together with touchmote and supermodel 3 . Then the problem here is again the controllers . Touchmote will then create 2 virtual xbox controllers . Again 2 extra positions in your controller setup .
ninja2bceen Posted October 3, 2018 Posted October 3, 2018 Sounds like you need to set up joytokey so your controller pushes keystrokes.Check my channel out Sent from my iPhone using Tapatalk Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
