craiganderson Posted June 3, 2014 Posted June 3, 2014 using mednafen works well but this game show up vertical whereas the other games are horizontal the video from emumovies is horizontal tried two different roms anybody elses show up vertical? or horizontal? also the buttons dont seem to make sense for example, left stick is fire button etc i know i have buttons mapped correctly work for all other games thanks for any info http://craigandersonthemes.weebly.com/
craiganderson Posted June 3, 2014 Author Posted June 3, 2014 ill try this http://forum.fobby.net/index.php?t=msg&goto=2120& http://craigandersonthemes.weebly.com/
craiganderson Posted June 3, 2014 Author Posted June 3, 2014 actually the video from emumovies IS vertical my bad how are u guys playing this with the bezel of the handheld?? thanks http://craigandersonthemes.weebly.com/
craiganderson Posted June 3, 2014 Author Posted June 3, 2014 looks like there are multiple VERTICAL type games.....for wonderswan color http://craigandersonthemes.weebly.com/
craiganderson Posted June 4, 2014 Author Posted June 4, 2014 made its own bezel with its own xpadder setup for all the vertical games seems to work 1T9jBxeSTZQ http://craigandersonthemes.weebly.com/
knewlife Posted June 4, 2014 Posted June 4, 2014 I modify the madnafen module to set games in horizontal or vertical mode. For the controls I setup a local emulator that's is identical to the global one.. Buts allow me to setup a single key profile for all vertical games. I can upload if you wish with the inis included ... EmuLink (Canal de Youtube) | Main Menu Changer | HyperArchiver Version 0.0.0.17 | HSBezel
craiganderson Posted June 4, 2014 Author Posted June 4, 2014 Yes please Sent from my iPad using Tapatalk http://craigandersonthemes.weebly.com/
knewlife Posted June 4, 2014 Posted June 4, 2014 https://www.dropbox.com/s/7terduasdm74kfw/Mednafen.zip Please backup your Mednafen module folder, and remember i rename the module so you have to change your mednafen emulator to point to it. Also i change the default values for adjust the bezels in atari lynx and wonderswan (they are values in pixes, due to the bezel system not being able to setup this automaticaly). i use this bezels and they fit perfectly: /Upload Here/Knewlife/MEDIA/HyperLaunch Media/Bezels/Bandai WonderSwan Color (on the FTP). And for finish you have to create an emulator inside the bandai wonderswan color system (or globaly but i use it in local settings) identical to the Mednafen (call it MednafenVert), this will allow you to assing this emulator to every vertical game, allowing you to setup a single "vertical kermaper profile". Here is the ini with the setup, so you don't have to do it manually: https://www.dropbox.com/s/n4c7n0zvkgjhivk/Games.ini Must be place here: HyperLaunch\Settings\Bandai WonderSwan Color I change the setting in mednafen that virtualy rotate controls to false... So I can simply use the vertical profile to map keys. Hope is not so complicated. EmuLink (Canal de Youtube) | Main Menu Changer | HyperArchiver Version 0.0.0.17 | HSBezel
craiganderson Posted February 13, 2015 Author Posted February 13, 2015 somebody asked me a question about the outcome of this thread will have to double check but i think i ended up using same emulator for both horizontal / vertical games just made separate xpadder profiles for vertical games ....i think here are my xpadder profiles for wanderswan color if anybody wants them Bandai WonderSwan Color.zip http://craigandersonthemes.weebly.com/
