Demul starts minimized from Rocketlauncher
SpatzST
As with all my emulators, I run them through Rocketlauncher.  So far i've had no issues with the way anything is setup but Demul is giving me problems.  I can launch the emulator/games directly from inside RL with no problem, but when I attempt to do so from Hyperspin, it seems like it attempts to load (LED Blinky begins speaking the buttons) but then nothing happens.  Demul doesn't launch, nothing seems to happen at all.
The issue actually seems to be that having RocketLauncher running in the background stops it from loading.  If I manually exit RocketLauncher it will load, if I leave RL running in the background it will fail.  Is there a way to make RL close after exiting an emulator?
third edit.... I updated Demul and it works now... however it starts minimized and I can't figure out why yet :)
