kudrun Posted June 12, 2019 Posted June 12, 2019 TLDR - LEDBlinky will only start and light up my controls once MAME has loaded, but not when the FE (Hyperspin) first loads (i'm using RocketLauncher) Programs used: HyperSpin, HyperHQ, RocketLauncher, RocketLauncherUI, MAME, LEDBlinky - I followed along to a guide on how to install HS, MAME, and RL - I then followed along to the great Youtuber Maverick’s Arcade in setting up LEDBlinky. - I’ve set up a basic 1 frame animation for the default colours I want whilst not in game (FE Active etc..), and added an FE Start-up and FE Quit animation. - All buttons are wired up correctly and each program seems to be talking to each other. I can launch a game in MAME, and the colours change based on the colour.ini etc…great - However, LEDBlinky doesn’t run the FE Start-up when I launch HS. It only runs that once I launch a game through MAME. Game runs, it flashes white for second, then runs the FE Start-up animation, then switches to the specific game colours. When I exit the game back to the menu, FE Active kicks in. But when I close HS, The FE Quit animation doesn’t run and after HS is closed, the FE Active stays lit. - So, it seems like everything is working, just not in the right order. Or, something isn’t configured correctly. - If I start LEDBlinky, then launch HS, same thing. - If run a HS Start-up Script to run LEDBlinky on HS launch, same thing. - But, I’ve checked the Debug.log and HS Log.txt and LEDBlinky does launch at the same time as HS does when the Start-up Script runs. Some further info that might help: - I have LEDBlinky Disabled in HyperHQ (I was advised that it would conflict with RL-LEDBlinky communication) - I have LEDBlinky Enabled in RocketLauncherUI and set to “Enabled - All” - In LEDBlinky I have the FE set to “Other Front-End” My guess is, it’s something simple, and I’m just missing it. Any help you might be able to give me would be most appreciated. Ben.
