duncanator Posted August 1, 2019 Posted August 1, 2019 So, I've watched at least a dozen videos regarding bezel setup in RocketLauncher for support in Hyperspin. I have the bezels in the RocketLauncher\media directory and set them up in the global as well as specific system setting to use RocketLauncher bezels. When I am on the MAME module in RocketLauncher and select a specific game to play, bezels appear, apparently loading them from MAME. When I launch Hyperspin and select the same game, no bezel appears. Do I need to make sure that there are no bezel files in the MAME\artwork folder? This bezel stuff has been plaguing me since December 2018 and I have yet to find the solution. Thank you!
griffin518 Posted August 2, 2019 Posted August 2, 2019 Check your MAME config and turn artwork off. If you haven't already, you should also set RL to use the MAME ini as well. Download my RocketLauncher bezels: http://hyperspin-fe.com/files/file/14367-griffin518s-bezel-depot/ Best of MAME HyperSpin XML: http://www.hyperspin-fe.com/files/file/11710-griffin518s-best-of-mame-xml-database/ Best of MAME bezel pack: http://www.hyperspin-fe.com/files/file/11711-griffin518s-best-of-mame-bezel-pack/ Custom MAME ini files w/HLSL settings: http://www.hyperspin-fe.com/files/file/11712-griffin518s-best-of-mame-mameuifx-ini-files/
duncanator Posted August 2, 2019 Author Posted August 2, 2019 I will check that out, as well as how to do that. Thank you!
