I need some help with xbmc and ledblinky please.
Natdiamond
I have it set to run from hyperhq. I'm using an ledwiz-16 with led blinky. and it works fine on HS and mame. But I'm having issues getting it to dance to the music. When I have the ledblinky configuration tool open, and I run a test, it will ask me to play some music. So if I open xbmc directly OR open HS and use my wheel to open xbmc in HS, all the dancing lights work to the music. But without the configuration tool open. when I re start HS, no dancing lights in xbmc. I tried running it from a batch file like described HERE. It runs fine but still did not get it working on its own. Any suggestions?
Thanks arzoo. I ended up having to go command line. Also making sure to use hyperHQ to start and end ledblinky.exe. Now it works like a charm with XBMC
Well arzoo, I'm still having issues. It seems that after I run the debug tool, or while it's running it, or while the config tool is running, the dancing lights work in xbmc. But after restarting HS. The dancing lights don't work with xbmc anymore. I see the ledblinky start animation start and run, then a few seconds later, the stop or end animation runs, the no dancing lights. In hyperHQ under startup, I have the start & exit programs set to ledblinky.exe with "LEDBlinky.exe 1" for start param and "LEDBlinky.exe 2" for exit. With the quotes. Can you take a look at my debug file please and maybe make heads or tails of it?
[06/12/2014 20:34:51]
[06/12/2014 20:34:51] LEDBlinky v6.0.0.0
[06/12/2014 20:34:51] Event: FEStart
[06/12/2014 20:34:51] Settings.ini ******************** BEGIN
[06/12/2014 20:34:51] [VersionInfo]
[06/12/2014 20:34:51] Major=6
[06/12/2014 20:34:51] Minor=0
[06/12/2014 20:34:51] Release=0
[06/12/2014 20:34:51] Build=0
[06/12/2014 20:34:51] [GameOptions]
[06/12/2014 20:34:51] LightGameControls=1
[06/12/2014 20:34:51] GamePlayLWAFile=<Audio Animation>
[06/12/2014 20:34:51] GamePlayAniJukeboxOnly=1
[06/12/2014 20:34:51] GamePauseLWAFile=
[06/12/2014 20:34:51] GamePauseSpeakControls=1
[06/12/2014 20:34:51] UseMameOutputs=0
[06/12/2014 20:34:51] LightPlayerStartCoin=0
[06/12/2014 20:34:51] GameStartLWAFile=<Random>
[06/12/2014 20:34:51] GameStartSpeakControls=1
[06/12/2014 20:34:51] GameStartSpeakPrimaryControls=0
[06/12/2014 20:34:51] GameStartSpeakName=0
[06/12/2014 20:34:51] GameStartStrobeName=0
[06/12/2014 20:34:51] GameStartSpeakText=
[06/12/2014 20:34:51] GameStartStrobeText=0
[06/12/2014 20:34:51] AbortSpeechAnyKey=0
[06/12/2014 20:34:51] SpeakControlsPrefix=
[06/12/2014 20:34:51] SpeakPrimaryControlsPrefix=Primary Control
[06/12/2014 20:34:51] [FEOptions]
[06/12/2014 20:34:51] FE=hyperspin
[06/12/2014 20:34:51] LightFEControls=0
[06/12/2014 20:34:51] DemoGameControls=1
[06/12/2014 20:34:51] DemoScrollDelay=0
[06/12/2014 20:34:51] DemoDuration=5
[06/12/2014 20:34:51] FELWAFile=
[06/12/2014 20:34:51] FEScreenSaverLWAFile=
[06/12/2014 20:34:51] FEScreenSaverRandomText=0
[06/12/2014 20:34:51] FEScreenSaverRandomTextDelay=60
[06/12/2014 20:34:51] FEScreenSaverRandomTextBerzerkMode=0
[06/12/2014 20:34:51] FEStartLWAFile=3forsweep.lwax
[06/12/2014 20:34:51] FEStartSpeakText=
[06/12/2014 20:34:51] FEStartStrobeText=0
[06/12/2014 20:34:51] FEQuitLWAFile=
[06/12/2014 20:34:51] FEQuitSpeakText=Thank you for playing on Charlie's Arcade. I hope to see you soon.
[06/12/2014 20:34:51] FEQuitStrobeText=2
[06/12/2014 20:34:51] FESpeakControlsKey=0
[06/12/2014 20:34:51] FEListSelectedLWAFile=
[06/12/2014 20:34:51] FEButtonFlash=2
[06/12/2014 20:34:51] FEButtonFlashSpeed=50
[06/12/2014 20:34:51] FESettingsFile=C:\Hyperspin\Settings\Settings.ini
[06/12/2014 20:34:51] HLActive=1
[06/12/2014 20:34:51] HLExeName=HyperLaunch
[06/12/2014 20:34:51] [MAMEConfig]
[06/12/2014 20:34:51] Colors_ini=C:\Users\Hyperspin\Desktop\LEDWIZ\LEDBlinky_5_1_0_3\LEDBlinky\Colors.ini
[06/12/2014 20:34:51] Mame_cfg_folder=C:\Hyperspin\Emulators\Mame 153\cfg
[06/12/2014 20:34:51] MameControllerFile=
[06/12/2014 20:34:51] UseMameDefaultForOtherEmulators=0
[06/12/2014 20:34:51] MameOutputBufferSize=
[06/12/2014 20:34:51] MameControlsFile=C:\Users\Hyperspin\Desktop\LEDWIZ\LEDBlinky_5_1_0_3\controls.ini
[06/12/2014 20:34:51] MameXmlFile=C:\Hyperspin\Emulators\Mame 153\gamelist.xml
[06/12/2014 20:34:51] UseMameToTriggerGameStart=0
[06/12/2014 20:34:51] [RandomText]
[06/12/2014 20:34:51] Text0=Get The Intruder
[06/12/2014 20:34:51] Text1=Intruder Alert!
[06/12/2014 20:34:51] Text2=I sense coins in your pocket.
[06/12/2014 20:34:51] [speech]
[06/12/2014 20:34:51] SpeechRate=0
[06/12/2014 20:34:51] SpeechVolume=100
[06/12/2014 20:34:51] Voice=Microsoft Anna - English (United States)
[06/12/2014 20:34:51] [AudioAnimation]
[06/12/2014 20:34:51] AudioDevice=0
[06/12/2014 20:34:51] AudioInput=0
[06/12/2014 20:34:51] SampleRate=30
[06/12/2014 20:34:51] AmplitudeMultiplier=500
[06/12/2014 20:34:51] AutoAmpMultTargetAvgLow=8
[06/12/2014 20:34:51] AutoAmpMultTargetAvgHigh=14
[06/12/2014 20:34:51] AutoAmpMultUpdateRate=2000
[06/12/2014 20:34:51] AAMode=1
[06/12/2014 20:34:51] AAGamePlayLWAFile=
[06/12/2014 20:34:51] AAGamePauseLWAFile=
[06/12/2014 20:34:51] AAFEActiveLWAFile=
[06/12/2014 20:34:51] AAFEScreenSaverLWAFile=
[06/12/2014 20:34:51] AACabAttractLWAFile=
[06/12/2014 20:34:51] TriggerMode=2
[06/12/2014 20:34:51] TriggerThreshold=25
[06/12/2014 20:34:51] TriggerFrequency=1
[06/12/2014 20:34:51] TriggerDeadZone=5
[06/12/2014 20:34:51] ControlFrequencyList=P1B1|1,P1B2|2,P1B3|3,P1B4|4,P1B5|5,P1B6|6,P1B7|7,P1B8|8,PAUSE|9,P1START|10,P1COIN|11,EXIT|12
[06/12/2014 20:34:51] ControlThresholdList=P1B1|12,P1B2|11,P1B3|10,P1B4|9,P1B5|8,P1B6|7,P1B7|6,P1B8|5,PAUSE|4,P1START|3,P1COIN|2,EXIT|1
[06/12/2014 20:34:51] LockTriggerFrequency=0
[06/12/2014 20:34:51] LockTriggerThreshold=1
[06/12/2014 20:34:51] Decay=4
[06/12/2014 20:34:51] SpectrumMode=1
[06/12/2014 20:34:51] SpectrumColor1=clBlue
[06/12/2014 20:34:51] SpectrumColor2=clBlue
[06/12/2014 20:34:51] SpectrumColor3=clBlue
[06/12/2014 20:34:51] SpectrumColor4=clBlue
[06/12/2014 20:34:51] SpectrumSingleAmpRange=1
[06/12/2014 20:34:51] [CabLEDs]
[06/12/2014 20:34:51] CabLEDsMode=0
[06/12/2014 20:34:51] CabLEDControllers=
[06/12/2014 20:34:51] CabFEStartLWAFile=
[06/12/2014 20:34:51] CabFEQuitLWAFile=
[06/12/2014 20:34:51] CabFEActiveLWAFile=
[06/12/2014 20:34:51] CabFEScreenSaverLWAFile=
[06/12/2014 20:34:51] CabGameStartLWAFile=
[06/12/2014 20:34:51] CabGamePlayLWAFile=
[06/12/2014 20:34:51] CabGamePauseLWAFile=
[06/12/2014 20:34:51] CabFEListSelectedLWAFile=
[06/12/2014 20:34:51] [JDR]
[06/12/2014 20:34:51] UseGPWiz49=0
[06/12/2014 20:34:51] UseUltraStik=0
[06/12/2014 20:34:51] UltraStikRestrictorType=0
[06/12/2014 20:34:51] UseServoStik=0
[06/12/2014 20:34:51] [OtherSettings]
[06/12/2014 20:34:51] MaxPlayers=4
[06/12/2014 20:34:51] CocktailMode=0
[06/12/2014 20:34:51] RandomAniExcludeSelected=0
[06/12/2014 20:34:51] PreloadAudioLib=0
[06/12/2014 20:34:51] GameStartDelayTimeout=20
[06/12/2014 20:34:51] LogFile=Debug.log
[06/12/2014 20:34:51] DisplayErrorsOnExit=0
[06/12/2014 20:34:51] ZipDebugFiles=1
[06/12/2014 20:34:51] LEDControllersOverride=
[06/12/2014 20:34:51] JDROverride=0
[06/12/2014 20:34:51] NoLEDs=0
[06/12/2014 20:34:51] SaveUnknownGames=1
[06/12/2014 20:34:51] SingleDebugSession=1
[06/12/2014 20:34:51] Settings.ini ******************** END
[06/12/2014 20:34:51] Detected LED Controllers: LW1
[06/12/2014 20:34:51] LEDBlinkyInputMap.xml ******************** BEGIN
[06/12/2014 20:34:51] [LEDWiz-1]
[06/12/2014 20:34:51] Port001=P1B1,S,KEYCODE_LCONTROL
[06/12/2014 20:34:51] Port002=P1B2,S,KEYCODE_LALT
[06/12/2014 20:34:51] Port003=P1B3,S,KEYCODE_SPACE
[06/12/2014 20:34:51] Port004=P1B4,S,KEYCODE_LSHIFT
[06/12/2014 20:34:51] Port005=P1B5,S,KEYCODE_Z
[06/12/2014 20:34:51] Port006=P1B6,S,KEYCODE_X
[06/12/2014 20:34:51] Port007=P1B7,S,KEYCODE_ENTER
[06/12/2014 20:34:51] Port008=P1B8,S,KEYCODE_LSHIFT
[06/12/2014 20:34:51] Port009=PAUSE,S,KEYCODE_P
[06/12/2014 20:34:51] Port010=P1START,S,KEYCODE_1
[06/12/2014 20:34:51] Port011=P1COIN,S,KEYCODE_5
[06/12/2014 20:34:51] Port012=EXIT,S,KEYCODE_ESC
[06/12/2014 20:34:51] LEDBlinkyInputMap.xml ******************** END
[06/12/2014 20:34:51] LEDBlinkyControls.xml: v1.0 01/16/2009 15:38:09
[06/12/2014 20:34:51] 5 mame games loaded from LEDBlinkyControls.xml
[06/12/2014 20:34:51] 3 emulator games loaded from LEDBlinkyControls.xml
[06/12/2014 20:34:51] Speak [<pitch middle="0"><spell>LED</spell>Blinky.</pitch>]
[06/12/2014 20:34:52] Received Event - Queue:[1] Msg:[3~LEDBlinky.exe 1].
[06/12/2014 20:34:52] Received Event - Queue:[2] Msg:[8].
[06/12/2014 20:34:59] Game Start Key (P1): 13
[06/12/2014 20:34:59] Game Start Key (P2): 69
[06/12/2014 20:34:59] Audio Animation successfully initialized.
[06/12/2014 20:34:59] Loaded LWAX File for FE Start: [3forsweep.lwax]. Single loop only.
[06/12/2014 20:35:00] FEStart Event Completed.
[06/12/2014 20:35:00] Event: FEEmulatorSelected [MAME] []
[06/12/2014 20:35:00] Emulator: [MAME]
[06/12/2014 20:35:00] Controls.dat INI file Version=0.141.1, Time=2011-01-05 18:17:26, Generated by=SirPoonga
[06/12/2014 20:35:00] 1057 games loaded from controls.ini
[06/12/2014 20:35:00] MAME.xml v0.153 (APR 7 2014)
[06/12/2014 20:35:01] Unknown Control Type in Mame.xml [bISHJAN: JOY 5 (HALF8)].
[06/12/2014 20:35:01] Unknown Control Type in Mame.xml [bONGO: JOY 5 (HALF8)].
[06/12/2014 20:35:02] Received Event - Queue:[2] Msg:[3~XBMC~XBMC].
[06/12/2014 20:35:03] Unknown Control Type in Mame.xml [FILETTO: JOY 3 (HALF4)].
[06/12/2014 20:35:09] Unknown Control Type in Mame.xml [MSHUTTLE: JOY 5 (HALF8)].
[06/12/2014 20:35:10] Unknown Control Type in Mame.xml [RADIKALB: JOY 1].
[06/12/2014 20:35:10] Unknown Control Type in Mame.xml [RFMPB: JOY 5 (HALF8)].
[06/12/2014 20:35:14] Unknown Control Type in Mame.xml [sWE1PB: JOY 5 (HALF8)].
[06/12/2014 20:35:14] Unknown Control Type in Mame.xml [TETRISKR: JOY 3 (HALF4)].
[06/12/2014 20:35:14] Unknown Control Type in Mame.xml [TETRSARK: JOY 5 (HALF8)].
[06/12/2014 20:35:14] Unknown Control Type in Mame.xml [TIMESCAN: JOY 5 (HALF8)].
[06/12/2014 20:35:15] 8783 games loaded from Mame.xml
[06/12/2014 20:35:15] 20210 clones loaded from Mame.xml
[06/12/2014 20:35:15] 1389 games loaded from Colors.ini
[06/12/2014 20:35:15] FEEmulaterSelected Event Completed.
[06/12/2014 20:35:15] Event: FEGameSelected [LEDBlinky.exe 1] [] []
[06/12/2014 20:35:15] Event: FEGameStart
[06/12/2014 20:35:15] No controls found for [LEDBLINKY.EXE_1]. Use the LEDBlinky Controls Editor application to import the Unknown Game and assign controls.
[06/12/2014 20:35:15] Not a jukebox. Skipping GamePlay animation.
[06/12/2014 20:35:15] Event: FEListSelected
[06/12/2014 20:35:15] Event: FEEmulatorSelected [XBMC] []
[06/12/2014 20:35:15] Emulator: [XBMC]
[06/12/2014 20:35:15] Event: FEGameSelected [XBMC] [] []
[06/12/2014 20:35:15] ROM/Game: [XBMC] Controls: [XBMC-DEFAULT]
[06/12/2014 20:35:15] Control List for XBMC: |P1_BUTTON1|P1_BUTTON2|P1_BUTTON3
[06/12/2014 20:35:15] Control Speech List for XBMC: |||
[06/12/2014 20:35:15] None of the controls for [XBMC-DEFAULT] are assigned any Input Codes. Use the LEDBlinky Controls Editor application to configure game controls.
[06/12/2014 20:35:15] Loaded LWAX File for Game Start: [Pattern22.lwax]. Single loop only.
[06/12/2014 20:35:16] Game LED Data
[06/12/2014 20:35:16] LED Controller [LEDWiz-1] Intens: 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0
[06/12/2014 20:35:16] LED Controller [LEDWiz-1] States: 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0
[06/12/2014 20:35:16] Speech LED Data
[06/12/2014 20:35:16] Game Start LED Data
[06/12/2014 20:35:25] Received Event - Queue:[1] Msg:[4].
[06/12/2014 20:35:25] Event: FEGameQuit
[06/12/2014 20:35:32] Received Event - Queue:[1] Msg:[3~LEDBlinky.exe 2].
[06/12/2014 20:35:32] Event: FEGameSelected [LEDBlinky.exe 2] [] []
[06/12/2014 20:35:32] Event: FEGameStart
[06/12/2014 20:35:32] ROM/Game: [LEDBLINKY.EXE_2] Controls: [XBMC-DEFAULT]
[06/12/2014 20:35:32] Control List for LEDBLINKY.EXE_2: |P1_BUTTON1|P1_BUTTON2|P1_BUTTON3
[06/12/2014 20:35:32] Control Speech List for LEDBLINKY.EXE_2: |||
[06/12/2014 20:35:32] None of the controls for [XBMC-DEFAULT] are assigned any Input Codes. Use the LEDBlinky Controls Editor application to configure game controls.
[06/12/2014 20:35:32] Loaded LWAX File for Game Start: [Pattern43.lwax]. Single loop only.
[06/12/2014 20:35:32] Received Event - Queue:[1] Msg:[2].
[06/12/2014 20:35:35] Game LED Data
[06/12/2014 20:35:35] LED Controller [LEDWiz-1] Intens: 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0
[06/12/2014 20:35:35] LED Controller [LEDWiz-1] States: 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0
[06/12/2014 20:35:35] Speech LED Data
[06/12/2014 20:35:35] Game Start LED Data
[06/12/2014 20:35:35] Event: FEGameQuit
[06/12/2014 20:35:35] Event: FEQuit
[06/12/2014 20:35:35] Speak [Thank you for playing on Charlie's Arcade. I hope to see you soon.]
