Project 64 "ChangeWindow Exeption" Error
RetroJay
Hey guys.
I've searched the web for a solution ti this error but i couldnt find any..
Anyone else managed to solve thos error? Everytime i quit project 64 emulator i get a directx3d8 error saying "ChangeWindow exception"
Thanks in advance!
Are you using version 1.6? (I think thats the one I used and got the same error) I changed to version Project64 v2.0.0.14 and the error went after that.
Might be nothing, but I am trying to remember how I solved it: Have you set P64 to exit completely when you press ESC I remember that being an issue and the reason I upgraded the P64 emulator to V 2.0.0.14?
If not to do it:
Options> Settings>Keyboard Shortcuts at the top change it to game playing (fullscreen) open the + on OPTIONS, select fullscreen and remove the ESC key that is assigned to it (If ESC Isnt assigned to it search for where ESC is assigned and remove it) then open the + on FILE MENU and click EXIT and remove the option selected and assign ESC to it, apply and that should hopefully fix it.
If so then I am all out of ideas for now.
I used to use 1.6 then upgraded too. In the end I went back to 1.6 as the Emu was just too buggy to use with this front end. It maybe a better Emu slightly but the 1.6 is far more stable with hyperspin.
In fact I went with the modded version of 1964 after all the hassle. Once you get it going you dont have any worries at all. Trust me... even if you get Project 64 working (amazing emu), after a while things will go wrong.
If not to do it:
That was it!, that made it work!! :D Thank you!
I think the error is a bug happening when you have a button assigned to different functions, in my case it was the ESC button, and that did it!
