HyperSpin randomly doesn't launch
SuperPang
I run Windows 10 and boot directly into HyperSpin 1.5.1 via Instant Sheller. HyperSpin usually boots fine. However, 10% of the time, my computer boots, displays the desktop, and never shows the frontend.
Whenever this problem happens, a HyperSpin process is running in Task Manager but I can't alt-tab into it. Also, HyperSpin doesn't write to log.txt.
Has anyone run into similar issues?
All the time. And also sometimes when exiting, the hyperspin process is still in running.
Same issues with HyperHQ and Hypertheme.
I just wrote an AutoHotkey script to work around this. It launches HyperSpin, waits 15 seconds so the program can launch, and then checks to see whether a log file was created. If there's no log, it closes HS and tries again.
; Delete existing log file
FileSetAttrib, -R, C:\HyperSpin\log.txt
FileDelete, C:\HyperSpin\log.txt
; Keep launching HyperSpin until a log file is created
Loop {
	Run, HyperSpin.exe, C:\HyperSpin\
	Process, Wait, HyperSpin.exe
	Sleep, 15000
	; If a log file wasn't created, HyperSpin didn't load properly
	if (!FileExist("C:\HyperSpin\log.txt")) {
		Process, Close, HyperSpin.exe
		Process, WaitClose, HyperSpin.exe
		continue
	break
So far, so good!
