Disable game pad support in specific games..
shambles1980
i want to dissable gamepads in specific games.. for instance cuphead.. cuphead detects my arcade stick as a game pad. and because i also use joytokey It also decided that fire = player 2 join.
if possible i want to select which controller it does not detect, because "again" cuphead for some reason does not allow two player keyboard play. So i want player 1 to be keyboard and player 2 game pad.
i am using cuphead as an example, but there are many other games that have similar issues that i can easily fix if i can just disable detection of specified game pads.
I had a look at dxwnd but it does not seem to work as intended.
i am 99.99999% finished with my hyperspin setup, so please dont say "use rocket launcher" or something like that. everything else i have been able to do via bat files, ahk or a combination of both. and although it seems rediculous it found that easier than trying to deal with rl.
ok scratch this post..
changing the hid driver for the device from game pad to only hid device in dev manager only partially worked. so still need some sort of help.
i did try an x-input wrapper but that just stopped cuphead from starting.
and as i think it is reliant, i am using gog versions of games as the cab will not be connected to the network.
