Slagcoin button layout help with angles and extra dots
I plan to use the standard Japanese arcade layout.
https://www.slagcoin.com/joystick/layout/cluster36_s.png
I have a horizontal lines across my control panel to line up the prints. If I rotate the print out so the angled box is on my horizontal lines the buttons are comfortable for me, but should I use the extra dots to change placement of buttons because I angled it? What about the joy stick should I use the dot below it? I get the dot to the right of the joy is for using when you remove the left two buttons.
Or am I just completely wrong? Any help thanks for your time
