issues out the box
r73
Hey guys, brill site.
Now I am looking for some help, hyperspin is awesome but I am having some issues with both the dreamcast & mame emulations.
out the box, both the mame and dreamcast emulations would throw up a black screen and pretty much nothing else, I did a bit of digging around on the net and some how come about setting redream up as the launcher instead of the stock one however now it will load within hyperspin it just takes me to the redream loader instead of starting the actual game. I am no coder but this is what the ini file looks like now.
Ini >>>
[exe info]
path=H:\hyperspin\emulators\Sega Dreamcast\
rompath=Roms/Sega Dreamcast/roms/
userompath=true
exe=io.recompiled.redream/io.recompiled.redream.MainActivity
romextension=chd,CDI,cdi,gdi,GDI
parameters=cores/redream_libretro_android.so
searchsubfolders=false
pcgame=false
winstate=HIDDEN
hyperlaunch=true
Per_Game_Modules=false
Skipchecks=false
Hide_Cursor=use_global
Hide_Desktop=use_global
Hide_Taskbar=use_global
CPWizard_Enabled=use_global
CPWizard_Delay=use_global
CPWizard_Params=use_global
Fade_In=use_global
Fade_Out=use_global
Fade_Color=use_global
Fade_In_Duration=use_global
Fade_Out_Duration=use_global
Fade_In_Delay=use_global
7z_Enabled=use_global
7z_Extract_Dir=use_global
7z_Delete_Temp=use_global
Keymapper_Enabled=use_global
Keymapper=use_global
MultiGame_Enabled=use_global
MultiGame_Background_Color=use_global
MultiGame_Side_Padding=use_global
MultiGame_Y_Offset=use_global
MultiGame_Image_Adjust=use_global
MultiGame_Font=use_global
MultiGame_Text_1_Options=use_global
MultiGame_Text_1_Text=use_global
MultiGame_Text_2_Options=use_global
MultiGame_Text_2_Offset=use_global
MultiGame_Use_Sound=use_global
MultiGame_Sound_Frequency=use_global
MultiGame_Exit_Effect=use_global
MultiGame_Selected_Effect=use_global
MultiGame_Use_Game_Art=use_global
MultiGame_Art_Folder=use_global
[filters]
parents_only=false
themes_only=false
wheels_only=false
roms_only=false
[themes]
use_parent_vids=false
use_parent_themes=false
animate_out_default=false
reload_backgrounds=true
[wheel]
alpha=.15
small_alpha = .5
style=normal
speed=high
pin_center_width=500
horz_wheel_y=512
vert_wheel_position=right
y_rotation=center
norm_large=360
norm_small=230
vert_large=450
vert_small=150
pin_large=500
pin_small=200
horz_large=240
horz_small=150
letter_wheel_x=800
letter_wheel_y=384
text_width=700
text_font=Style4
small_text_width=260
large_text_width=400
text_stroke_size=6
text_stroke_color=0x000000
text_color1=0x00BFFD
text_color2=0xFFFFFF
text_color3=0x00BFFD
color_ratio=139
shadow_distance=0
shadow_angle=45
shadow_color=0x000000
shadow_alpha=1
shadow_blur=0
[pointer]
animated=true
x=975
y=384
[video defaults]
path=H:\hyperspin\Media\Sega Dreamcast\Video\
[sounds]
game_sounds=true
wheel_click=true
[navigation]
game_jump=100
use_indexes=false
jump_timer=400
remove_info_wheel=true
remove_info_text=true
use_last_game=false
last_game=Blue Stinger (U)
random_game=false
start_on_favorites=false
[Special Art A]
default=true
active=true
x=512
y=720
in=0.4
out=0.4
length=3
delay=0
type=normal
start=bottom
[Special Art B]
default=true
active=true
x=512
y=740
in=0.4
out=0.4
length=3
delay=0
type=fade
start=none
[Special Art C]
active=false
x=512
y=384
in=0
out=0
length=3
delay=10
type=fade
start=none
[Game Text]
game_text_active    = true
show_year           = true
show_manf           = true
show_description    = true
text_color1         = 0x4C86CF
text_color2         = 0x4C86CF
stroke_color        = 0x000000
text_font           = Style3
text1_textsize=26
text1_strokesize=7
text1_x=32
text1_y=610
text2_textsize=36
text2_strokesize=8
text2_x=30
text2_y=640
MAME
Now I havnt touched the mame settings because clearly I don't know what im doing but has anyone else experienced problems with launching mame and any first points to look at.... all apps are up to date.
much appreciated.
  • 11 months later...
Ini >>> Wordle
Someone please respond.
