Sledge Posted April 16, 2021 Posted April 16, 2021 A bit of backstory: I loaded Windows 10 onto a Dell 9010 with an R5 230 GPU, with Calamity's drivers, everything seemed ok, until starting HyperSpin, and then when the theme loads for a Mame game (I assume other systems would be the same), the sound plays, but there is a 5 second delay to the video playing. Through searching i found the issue with flash/green videos/videos not playing etc (though i thought that had been fixed), but with the depreciation of flash, it is getting harder to get this installed and fixed. (we used to right click on a video being played in firefox, and disable hardware acceleration), but now we can't do that... There's 2 things you have to do to get this fixed: If not there already, create 2 folders: C:\Windows\System32\Macromed\Flash\ and C:\Windows\SysWOW64\Macromed\Flash\ In those folders, create a plain txt file called mms.cfg, you need to put this line in it: DisableHardwareAcceleration=1 Confirmed: The friend that helped me work this out just said you don't actually have to install Flash for this to work, but just create those folders/files and it will work. That's it! Enjoy!
Sledge Posted May 5, 2021 Author Posted May 5, 2021 Have confirmed the fix on my other machine and it definitely works Have updated OP
