HyperMarquee and EDS - Animated marquees just playing once, not looping
Hey Guys,
Just finished configuring HyperMarquee with EDS, the marquee videos play great and everything is looking great.
Only one issue left, the mp4 marquee only play a single time until completion and then blank screen. Is there any setting when using animated marquees to make vlc loop?
Did I miss an argument that can be added? Tried a different vlc version and seems newer ones don't work at all now, so definitely have to use an older release as there is a plugin error when starting Hyperspin with any recent version of VLC.
Any help is appreciated!
Thank you!!
Anyone has any idea about this?
Have not seen any build have the marquee videos loop.
Any way to send the loop argument to vlc to force the mp4 videos to loop? Seems like that should be possible as vlc is just a window playing the marquee video.
Any other solution to get this to work?
 Or does anyone has access to the hypermarquee source code so I check the functions and recompile a new version if that's missing?
Thank you!
