kllngtme Posted November 27, 2022 Posted November 27, 2022 Just picked up a retroid pocket 3 handheld and have been struggling getting hyperspin to launch. I essentially just used the same folder I'm using for my Nvidia shield tv which works. The rp3 uses android11 which I wasn't sure was part of the issue. The last thing is that I'm not sure if the folder structure is correct for the build of the apk thats out. When I plug and mount an SD card to move apps and expand my storage, the internal storage folders almost change to just be the sdcard. So when I plug into windows to side load apks or transfer roms, the folder structure only shows as SanDisk SD card.. With hyperspin it opens and closes right away.. Any ideas?
kllngtme Posted November 28, 2022 Author Posted November 28, 2022 OK so it's not the folder structure. It recognizes what folder as I realized the popup showing the missing data isn't popping up. Moving on, My shield folder works with no issues.. I didn't realize the note about Hyperspin being exclusive for NVidia OpenGL drivers? I'm not sure if this is why it crashes but is there another build to test out possibly? @reznnate, maybe you could help. Is this stuck on Nvidia hardware?
