HyperSpin Install Files v1.3.2.0 Joystick Problems
pyromaniac4382
I have downloaded the HyperSpin Install Files v1.3.2.0 and setup my keyboard for my initial testing of this software. It looks like everything runs as normal with my keyboard.
My arcade cabinet controls are hooked up via a XIN-MO encoder board which is recognized by windows, and I have verified that all of the controls work under the windows controllers testing area.
I then set up my XIN-MO controller in HyperHQ by pressing the set option, and setting each of the controls, and this works correctly.
I set up both "joysticks" (1 & 2) this way. (The controls are all controlled by a single XIN-MO with dual player channels.) I have both "joysticks" enabled. I loaded Hyperspin, and neither of the joysticks work, but the keyboard still works correctly.
I exited Hyperspin, went back into HyperHQ and tried deselecting one of the enabled "joysticks", and started HyperSpin back up, but still the keyboard works, and joystick does not. I tried the other enable on the joystick as well with no luck.
Both joysticks have also been tested in numerous individual emulators outside of Hyperspin, and were successful allowing me to play games freely.
Please advise.
(EDIT: Could this please be moved to HyperSpin Support, didn't realize this was HyperPin)
(EDITED: Moved by JackHammerSalm)
A very frequently asked question! It's a known bug. See here: http://www.hyperspin-fe.com/forum/showthread.php?t=34838
