CydXero Posted January 12, 2025 Posted January 12, 2025 setting up controls. In the Mapping, when I try to change the button is says key is already assigned...? EDIT!! I ran the exe as admin. Problem solved. CydXero
Dazz Posted January 12, 2025 Posted January 12, 2025 8 minutes ago, CydXero said: setting up controls. In the Mapping, when I try to change the button is says key is already assigned...? EDIT!! I ran the exe as admin. Problem solved. Was it a key that was already assigned to one of the other players? I normally delete/unmap all controls, and then only setup controls for player 1.
CydXero Posted January 12, 2025 Author Posted January 12, 2025 I ended up deleting the controller and readding it. The deleting of each key didn't work. I didn't try delete and then save. 1 CydXero
