I am trying to get a cart to go into a console the console is one layer and the cart is another layer.
on Hyper theme every thing works
the cart sit in the console and the console layer on top
but when you publish it the cart doesn't go under the console layer  it goes on top.
i have made the cart come down from the top so it look like your putting the cart in the system.
Am on Hyperspin 2 Theme maker and in the theme maker it works the cart is below the Console.
But when you publish it make the cart layer higher then the  console
there no artwork 3 or 4 I think your talking about hyperspin 1
It appears that this theme is not public for me to review. Is that correct? I wonder if it has something to do with the name of the layer being “Layer”.
Yes that correct it the first one I done and I wasn't going to publish it untill it was working. I never   knew you could rename the layers. Did you want me to public publish it so you can have a look.
Yes, if you don’t mind. I’ll still report it as a glitch but want to see if the same thing happens for me.
