With Hyperspin 2 in development, I've been working with the new HyperTheme a lot, and it is quite impressive to see what can be done. So I wanted to start this thread to show what I'm working on; to explain some of my process, and to demonstrate some of the capabilities of HT's new tools. Back when we used to announce our themes, I found it inspiring, motivating, and even educational at times. Hopefully this thread will do the same for others and help to spark the HS theme building community again.
Please feel free to ask questions about any processes or techniques I use. I'm not a pro, but I kinda know what I'm doing.
Here are the first two ArcadePC themes that I did: Storm Racer G (SRG) and Storm Rider (StormRider). For Storm Rider, I used a lot of screen captures for the bikes and details. Then I upscaled them with an online tool (https://www.iloveimg.com/) and cleaned up any details in Photoshop. For clean edges on cut out artwork, I use the pen tool to create vector masks.
Side note: I am not a fast theme builder like some of the greats from the past, but I do strive to make high-quality themes every time.
Next up is Crazy Ride by UNIS. This one had a nice wallpaper/background readily available, but I needed to cut out the cars to animate it.
I used Photoshop's "generative fill" as the first step to replace the gaps. I had to try multiple variations to get close to the desired outcome, and then I cut and pasted several sections together. It's not perfect, but if you don't study it too much, it looks pretty good.
I wanted the yellow car to move in from off screen and hover, so I had to rebuild the front corner that was cut off in the wallpaper. Generative fill got me the approximate shape that I wanted (again, it took several variations). Then I copied and pasted the headlights and fog lights to finish it off.
I got the best title that I could find, upsized it, and cut it out cleanly with the pen tool. Then I zoomed in and made additional touchups by hand. To make it a more dynamic and integral part of the theme, I changed the perspective too.
Still amazes me how you are using the toolset to make all that happen. I have a few more for you to play with and break my brain again if you want lol @rondar
Instagram : baddeolv
Facebook : Brian Addeo
Anytime, man!
Night Hunter - After Dark, Chapter 2
This is one of my favorite themes so far. And I spent a ridiculous amount of time on it, so this post may be a little lengthy.
I started off with a title screen snapshot and filled in the gaps with generative fill. I used multiple variations and then cut-and-pasted the best bits together.
I initially wanted the main hunter character in the theme. I tried multiple characters from screenshots, flyers, and arcade machine photos, but I couldn't get the results as good as I wanted. And that's when I decided the werewolf from the title screen would be the star. I upscaled it, recolored it and enhanced the hair texture.
To animate it, I needed parts for the movement. First, I cut out the hand and rebuilt the right fingers. I used a mixture of generative fill, copy/paste and manual retouching with a brush to repair the hand and arm stub. Then I copied/pasted the lower jaw and "beard" so it would cover the original jaw when the mouth partially closed. I then copied the eye and surrounding area so I could make the eyes glow. (I just painted a brighter yellow over the eyes on the new layer.)
The logo from the title screen was cool, but the simpler, bolder one looked more "arcade" to me and it's the one that I saw on most arcade photos. So I found the best source I could, upscaled it and cut it out with the pen tool. Btw, I always use the path to create a vector mask. Then I can adjust the edge later if needed. Another tip is to use the layer style(s) inside stroke and/or an inner glow to even out any jaggies or color variations on the edges of your cut.
And finally, I made a video frame to match the title. I used a gradient overlay for the blue stroke and applied a mirrored variation of the lightning from the title.
a6eec28e-b0fb-4a9c-b0c6-e14a69451efb-3799b6ef-6f3d-45c9-97db-8a62dda35053-arcadelogo.png.b83997cd5e4348e42f33cc43d863bb8a.pnga6eec28e-b0fb-4a9c-b0c6-e14a69451efb-3799b6ef-6f3d-45c9-97db-8a62dda35053-videoframecombinedRASTER.png.bea581667bf527ddf446ed83d27ac0be.png
Put that all together with some HyperTheme magic and you get this:
Elevator Action Invasion
See it in action:
How to do it?
The two main features of this theme are the muzzle blast/glow and the elevator door. For the blast/glow, I cut out the characters and then duplicated that layer. For the layer where the gun was not firing, I rebuilt the front of the gun using a reference image. I then changed the levels so that layer appeared a little darker. In HyperTheme (HT), I looped an opacity change for the blast layer (which is placed on top) so it looks like the characters are lit up when the gun fires.
For the elevator doors, I just duplicated the background layer with a door cutout. This layer then fades in to hide the doors.
Raccoon Rampage
 (Sorry for the low quality video)
For the animation, I separated the arm cannon from the body and extended the gray stub/joint so the cut would not be visible when the arm rotated. The ball of light is 3 layers. The separate shadow layer comes in from the bottom when the raccoon mech drops from the top.
The House of the Dead III
I separated the woman's arm at the shoulder so I could make it rotate a little (the lower hand is off-screen, so it doesn't matter that it doesn't line up correctly).
The lightning effect is created by adjusting the brightness and opacity of different layers.
And then lastly, I drew the video frame by hand to match the look of the logo.
Crazy Speed Arcade
Simple theme created by cleaning up and modifying in-game screenshots.
The background overlay and video make nice use of the reveal shaders.
One of the most challenging parts was cleaning up the title with the tire tracks and all the other markings. The previous transparent logo was far from clear.
I started by maxing out the contrast and brightness of a title screenshot. Then I selected the black sections with the magic wand tool, right-clicked and chose "Make Work Path". Then I could use that path to create a vector mask and modify that path to my liking. (There were a ton of other steps to make it what you see now, but that was the start.)
hmm...An old dude once told me that the magic wand tool should never be used for cutting out artwork because of the self named "jaggies" it produces.  He also made a point to give examples, side by side, and zoomed,  to show me the undeniable difference in quality achieved by using the pen tool to cut razor sharp, clean edges.  He's probably in the old folks home now though because this happened about 10 years ago and he was an old dude then already.  Plus he was already a little blue in the face... 😉  I think i have a picture from my last visit actually
Firefly_elderly -blue man group- members in retirement home in wheelchair 282373.jpg
  • Haha 1
Don't you worry. Vector mask was applied after the wand tool and final edges were plenty clean. (And this was blotches, not like the clean lines of an anime character for example) 😉
You wore your good clothes too! lol
just read the last line....you sumbitch, i cant even argue with you.  however i was over the triple digits on creating theme layouts and was losing steam lol
After Dark
This theme was a huge pain in the butt, but the end result looks pretty cool. I used the flipbook feature in HyperTheme (HT) to take individual images and create an animation. With traditional game sprites this would be a relatively simple operation, but - since I'm a glutton for punishment - I took in-game snapshots of the opening video sequence as the werewolf was running. This gave me 17 images like this to cut and clean up:
I used "remove background" in Photoshop to get started. Then I cleaned up each image and filled in gaps as necessary.  I centered each image on the canvas and saved them as transparent png's in numerical order. This gave me this:
To get a smooth animation loop for the ground layer, I created two horizontal rock surfaces from the screenshots and used tiling to scroll the images in the theme. The foreground image is blurred and scrolls faster for added depth.
And the backdrop of the animation is an oversized moon background that moves slowly to the right.
And the final result:
Wartran Troopers
I wanted to use the mech/tank thing from this flyer (because it was the clearest image I found), but the leg was covered.
I tried AI first, but it did weird things...
flyer-ai-weirdness1.png.7d7cdcc03da7a21e03a67f5242981e1c.pngflyer-ai-weirdness2.png.f8ef561a389b084282d57eb542c9c2d1.png
I ended up copying the right leg and distorting the dimensions to match the approximate perspective.
To give a little movement to the theme, I chopped off the left arm (filled in the gap mostly by cloning) and created a little blast pattern by painting overlapping red, orange and yellow blotches. I added a little blur and then overlapped a motion blur layer. Voila!
Finished product:
Arctic Thunder & Ultimate Arctic Thunder
I redrew the logo in parts so I could animate them separately:
I isolated the snow so I could make it an animation layer that looked like the snow was moving.
The vid below isn't quite the final, but it was pretty close.
For the Ultimate version, I just recolored it based on the title screen coloring.
Ultimate Arctic Thunder Title Screen
Wangan Midnight Maximum Tune 5DX Plus
Pretty simple theme this time. Just upscaled the art and made a custom video frame to match the coloring of the logo.
Wacky Races
Fun theme featuring Muttley laughing animation. I redrew the character and split up the pieces so I could stack them and animate them.
Wangan Midnight R
I based the theme on the marquee:
I started with a redrawn title:
Then I found the manga cover that matched and upscaled an in-game city image for the background. I colorized the city image to resemble the red coloring on the marquee.
citycopy50.png.eac69ef2deee87cb1e1c50befaf34163.png red-bg.png.5dcb446ffcb3aa99b22c010189b0307b.png
I just shed a little tear... this stuff is awesome! i need to take a few days of from work. There is alot to go through with what you and Baddie pumped out, amazing stuff. I need some time to see everything and will report, but... loving what i am seeing guys. my weekend is booked with HT.
